Correct tire pressure (newb question)
   / Correct tire pressure (newb question) #1
pschrad
rosalia, wa
JD 870
Newb question here.
I have a JD 870 tractor that currently has turf tires mounted on it. Winter is coming and I am going to mount the Firestone Ag ties that came with it.
Could you suggest what the correct tire pressure should be for the rear Ag tires?
Firestone All Traction Field & Road
`12.4 x 24
   / Correct tire pressure (newb question) #2
Won't they have the pressure range stamped on the sidewall?
   / Correct tire pressure (newb question) #3
:welcome:
To the TBN forum pschrad. I found this: Max Load and Inflation: 1870 lbs at 16 psi, on the Firestone website.
   / Correct tire pressure (newb question) #4
Owners manual says 12-16 psi for that tire size.
Most helpful..Thanks,Jim
-Paul
   / Correct tire pressure (newb question) #6
Hi pschrad,
I'm about 17 miles NW of you and hoping some of this rain may soon become snow also. Have a good day. Oosik
   / Correct tire pressure (newb question) #7
Just a reminder - if you have 4x4, you need will want to make sure that the Ag rear tires are in proportion to the front tires (assuming you dont have Ag fronts as well)
On my 2320 R-4 tires - i put in 16# of air and that thing bounced like a kids ball.. I had to lower it to around 12# so it didnt jar my insides out..
brian
   / Correct tire pressure (newb question) #8
I'm with that guy. When the dealer delivered my tractor i kept bouncing enough to shut the engine off with the seat safety switch.
I lowered the pressure so i had full width contact on pavement and found that worked great as my MAXIMUM pressure. For roots and rocks you can get by with even less....
Tires are designed to flex, you don't need to worry about heat build up like in a car...
Thanks pat32rf and thatguy for your tips.......................most helpful.
Can't wait until we get some snow.
-Paul
UNUSED GREAT BEAR 1.5CY SELF DUMPING HOPPER (A51248)
UNUSED GREAT BEAR...
2013 CAT 950K WHEEL LOADER (A52472)
2013 CAT 950K...
1/2 '' Wolverine Universal Quick Attach Mount Plate (A51573)
1/2 '' Wolverine...
2012 Ford Fusion SE Sedan (A51694)
2012 Ford Fusion...
Echo SRM2620 Gas Trimmer (A52377)
Echo SRM2620 Gas...
IRONCRAFT 84" ROTARY MOWER (A51247)
IRONCRAFT 84"...
