Correct thermostat for 1020 gas Deere?
   / Correct thermostat for 1020 gas Deere? #1
Blueflint
Winchester, Ohio
Deere 1020
I almost have the engine back together in my 1969 135 ci gas 1020 (in frame rebuild after sleeves were leaking). I had picked up a replacement thermostat that Stant listed in their catalog, pn 45358, 180 degree. This evening while cleaning up the housing getting ready to assemble things, I noticed the thermostat I removed was 160 degree. This is a low hour (1,500) un-molested tractor and it appears to me to never been apart so I am tinking this is the original factory installed unit??????? The one I removed from the tractor is a Robert Shaw Controls Company unit. Was this factory installed? What temp should I use?
Thanks, Tony
   / Correct thermostat for 1020 gas Deere? #2
I think the 180 degree thermostat will be better no matter what tractor came from the factory with. Warmer operating temp. to a point is better than colder temp's.
   / Correct thermostat for 1020 gas Deere? #3
The factory thermostat for the gas was 160*. The diesel was 205*. 180* was optional for either engine. It depends on what you will be doing with it. If doing mostly light duty work, I would recommend the 180*. If you will be doing heavy work, (plowing for example) I would recommend the 160*. Should be a little less likely to have problems with vapor lock in hot weather. Just my opinion, for what it's worth.
I am going to run the 180 and see how it goes. I know on most water cooled carburated engines, 180 seems to work the best. I'll keep an eye on things and go from there. Thanks guys. Tony
TOW BEHIND FINISH MOWER (A50324)
TOW BEHIND FINISH...
2020 Nissan NV200 Cargo Van (A51692)
2020 Nissan NV200...
2012 OVERLAN KILL TRAILER (A53843)
2012 OVERLAN KILL...
2018 Chevrolet Tahoe (A51694)
2018 Chevrolet...
LOAD OUT INFORMATION (A53084)
LOAD OUT...
1272 (A50490)
1272 (A50490)
