Tractor Sizing Correct front tire size 155D
   / Correct front tire size 155D #1
champi
Pittsburgh Pa
Yanmar 155D
Hi someone replaced front tires with 155.12 automotive tires Tractor has 8-16 turf tires on rear. I checked yanmar owners and it lists 5.00 12 as fronts for 1300D (doesnt list 155d sizes) but most websites list 5-12 Is 5-12 the same as 5.00 12? I want to replace these tires with Ag tires . Has anyone changed from turf to Ag tires and kept the same rims? Thanks ,
   / Correct front tire size 155D #2
If you have 8-16 turf tires on the rear, use 6-12 turf tires on the front.
When you switch to 8-16 Ag tires on the rear, put 5-12 Ag tires on the front.
The size numbers are nominal, not exact, the 8-16 turf tire has a larger O.D. than an 8-16 Ag tire so you have to use a larger O.D. tire on the front.
As for using the same rims, I don't see what it would hurt.
Went with the 5-12 ag's....Seems to be fine
Thanks Gjamtrac!!
Tires (A50322)
Tires (A50322)
UNUSED NORTHERN UTV-50 AG MIST SPRAYER (A51247)
UNUSED NORTHERN...
UNUSED FUTURE STB47 TELESCOPIC BOOM (A51248)
UNUSED FUTURE...
2021 Club Car Carryall 500 Utility Cart (A51691)
2021 Club Car...
22002 (A51694)
22002 (A51694)
