Correct fluid level on NH 1920 e4x4 front axle housing?
   / Correct fluid level on NH 1920 e4x4 front axle housing? #1
2dawoodz
Bronze Member
Is the correct fluid level for the front drive housing just above the etched end of the dipstick? If the current fluid level is 1 inch above this mark should I drain or OK as is? Thanks!
   / Correct fluid level on NH 1920 e4x4 front axle housing? #2
Fill level is anywhere on the hashed portion of the dipstick. If yours is overfull, drain it to the proper level. Overfilling a non-vented axle such as yours will lead to pressure fluctuations greater than normal due to the decreased volume of air trapped in the housing and eventual seal failure. ideally, if the oil hasn't been changed in a while, you should drain a pint at a time from the final drive housings as this is typically where the dirtiest oil is found.
UNUSED FUTURE ML32 - 32" HYD MULCHER (A51248)
UNUSED FUTURE ML32...
UNUSED FUTURE FT-SB45 SILENT BREAKER HAMMER (A51248)
UNUSED FUTURE...
WOODS DS8.50 LOT IDENTIFIER 232 (A53084)
WOODS DS8.50 LOT...
2016 R and R Products 331 LP Reel Mower (A51694)
2016 R and R...
RYOBI 40V BRUSHLESS ELECTRIC 20" PUSH MOWER (A51248)
RYOBI 40V...
ECHO GT-225 GAS WEED EATER (A51248)
ECHO GT-225 GAS...
