Correct Dirt/Pond Scoop Size for Jinma 254
   / Correct Dirt/Pond Scoop Size for Jinma 254 #1
nt254
I am looking at buying a dirt/pond scoop for my tractor. It is a 25 hp. 4 wheel drive Nortrac/Jinma. I am unsure of what scoop size I need for this tractor. I would like a 30" scoop but I do not know if it will fit. I am concered about the scoop hitting the back tires when lifted (I have read some older posts where others have had this happen on other tractors). The inside width of the rear tires is about 37". The lift arms extend beyond the rear tires about 9". Should I get the 30" scoop of be safe and get a 24" ?? Any advise would be great.
Thanks,
Nt 254
   / Correct Dirt/Pond Scoop Size for Jinma 254 #2
I think that you should get the 30" because it will fit between your tires even if it extends far enough to hit them. The measurement is the length not the width. They both are the same width. I made a 30" dirt scoop that would barely hit the corners on my very small 1510D yanmar. It will be fine for you.
Mike
JMR Attachments 40" Mini Grapple (A50121)
JMR Attachments...
2005 Ford F150 XL Triton (A50120)
2005 Ford F150 XL...
PENDING SELLER CONFIRMATIONS (A52141)
PENDING SELLER...
2023 Trailerman Gooseneck (A50514)
2023 Trailerman...
7' Bush Hog 3 pt Mower (A50515)
7' Bush Hog 3 pt...
2023 Maxx-D TDX Tandem Dual Flatbed Tilt Trailer (A52748)
2023 Maxx-D TDX...
