Correct belly mowers for BX24?
   / Correct belly mowers for BX24? #2
These are the correct mower decks for a BX24 according to the Kubota website:
RCK54-23BX
RCK60B23BX
RCK54P23BX
As you probably know, BX mower decks follow a common basic design but have slight differences from one generation to the next.
   / Correct belly mowers for BX24? #3
yup --- thats right . i have the 60 inch deck andi recall it has 23bx words on it
   / Correct belly mowers for BX24? #4
The little tractor will handle a 60" belly mower just fine but not a 60" 3pt finishing mower. When I purchased mine new in 06, I informed the salesman that I wanted a 3pt finishing mower. He figured that since if it could handle the 60" belly mower that it would do the same with the finishing mower. After using the mower I noticed that the engine temp would run @ the 3/4 mark and if the grass was just a little taller it would run hotter. I took the machine back to the dealer a few times and all the would do is just run it @ 540 pto rpm with the mower turned on for a few hours outside the shop and could never get it to get to the temp. that I indicated. I tried to tell the that they needed to go cut grass with it. Anyway all they ended up doing was changing the instrument cluster, but that didn't solve the problem. I finally relocated the battery which was restricting air flow to the radiator and that helped much. I ended up meeting up with the salesman a few months later at a restaurant and he told me that he made an error in assuming that a 60" finishing would work, in fact it was recommended that a 48" was what I really was suppose to be running. Still using the 60", just have to keep a close eye on the temp. especially on those super hot days.
UNUSED RAYTREE RMBD72-72" DRUM MULCHER (A51248)
UNUSED RAYTREE...
2121 (A51244)
2121 (A51244)
2015 SkyJack SJ86T 4x4 86ft Telescopic Boom Lift (A52377)
2015 SkyJack SJ86T...
2019 RBR Venturi 380 (A53472)
2019 RBR Venturi...
2011 Autocar ACX64 Xpeditor coe t/a refuse (A52384)
2011 Autocar ACX64...
2021 JOHN DEERE 8R250 LOT IDENTIFIER 179 (A53084)
2021 JOHN DEERE...
