correct 1949 8N hood
   / correct 1949 8N hood #1
cfb
Bronze Member
Cleveland, Ohio
1949 Ford 8N, Ingersoll 448, Ford 16HP Diesel
hello everyone,
is there more than one "official" hood for a 1949 8N? My hood does not have the air filter little door on the right side (from the seat view). Should it?
on another in the family, I think a '50 or '51 has the door but no little canister fixed outside. Should it? Or was this an option
thank you, cfb
   / correct 1949 8N hood #2
the canister is an add on seperator cleaner. normally an 8n will have a louvered door with screen behnd it to block the big chunks from entering the oil bath air cleaner.
a 9n / 2n hood will not have that door as the air cleaner top is vented in one way or another...
thanks Soundguy, that's what I was afraid of. I'll probably be hunting for a replacement down the road. I perhaps should have suspected as the hood is a very dark grey, which I've only seen on 2Ns I believe and no Ford Script, whereas the fenders are the lighter color.
cfb
   / correct 1949 8N hood #4
unless you are going for originality.. you can simply ventilate it.. :)
2016 Dodge Charger SRT Hellcat Sedan (A53424)
2016 Dodge Charger...
2007 NLB Trailer Mounted Shell Side System (A53117)
2007 NLB Trailer...
Rockwell Model 19 Planer (A51695)
Rockwell Model 19...
2022 CATERPILLAR 242D3 SKID STEER (A51406)
2022 CATERPILLAR...
2019 CHEETAH T/A CHASSIS TRAILER (A53843)
2019 CHEETAH T/A...
2019 Bobcat 3400 4x4 Utility Cart (A51691)
2019 Bobcat 3400...
