Coolant leak
   / Coolant leak #1
MoMower
Platinum Member
PA
Massey GC1710.
Ok diesel gurus, seeing a bit of steam and residue at the bottom of the thermostat housing, guessing the thermostat went bad, stuck shut and blew the gasket.
Not seeing any reason I should see steam coming from there? (That’s the question)
I’m competent with gas motors, not as much with diesel (but I believe the cooling system is close).
2019 GC1723, 725 Hrs
Thanks!
   / Coolant leak #2
Thanks!
No reason there should be steam from the housing base. The gasket is likely bad as you surmise, but may or may not be related to a bad thermostat. Doesn't much matter, as you you'll want to replace the thermostat and gasket at the same time.
I do have a very vague recollection of having a steam leak at the thermostat housing on a vehicle years ago... There was a bleed screw on the housing that was leaking (?). Never seen a bleeder like that since.
   / Coolant leak #3
There is a bypass in the system if the thermostat sticks closed to relieve the pressure.
The thermostat gasket shouldn't be even close to being the weakest point in the system.
If the gasket is leaking, there is a bad seal there.
I would pull the housing, clean the surfaces and check for any defects. If none are found, replace the parts, reinstall, and see what happens.
   / Coolant leak
Thanks for the info!
About a week ago did have a small puddle (maybe a cup) of antifreeze on the ground and a low level in the reservoir. Never overheated, at least by the temp gauge.
   / Coolant leak
All that, it was a loose hose clamp, lol.
   / Coolant leak #6
that crap will bite you in the a$$ no matter what crap you are working on.
2018 Bobcat T590 Compact Track Loader Skid Steer (A50322)
2018 Bobcat T590...
2019 RBR Venturi 380 (A52748)
2019 RBR Venturi...
John Deere 5075E (A50120)
John Deere 5075E...
2017 Ram 4500 Bucket Truck (A52748)
2017 Ram 4500...
2015 JEEP PATRIOT (A51406)
2015 JEEP PATRIOT...
2019 Freightliner M2 106 Landscape Dump Truck (A50323)
2019 Freightliner...
