Coolant leak TC33DA
/ Coolant leak TC33DA #1
paul dyar
Bronze Member
Anderson S.C.
TC33DA
My tractor (TC33DA) is leaking coolant out of what appears to be a drain plug right above the oil filter. It is leaking where the thing screws into the block. I am hopping that all I have to do is take it out and put something on the threads. Has anyone had this problem?
Thanks,
Paul
/ Coolant leak TC33DA #2
It happened to me and many others. It's more of a "when" as opposed to "if" problem. It can be quite hard to get the plug out. It's very soft metal. I made a slotted socket but the drain fitting just sheared off. I then used a regular socket in an impact wrench and just barely got it out without rounding off the flats on the hex. I then replaced mine with a brass plug (and of course used paste pipe-thread compound) and got rid of the factory's stupid drain setup. You can't flush the block through the tiny hole anyway. Now I know I can get it out if I need to. Best of luck.
2019 VOLVO A45G OFF ROAD DUMP TRUCK (A62129)
2019 VOLVO A45G...
JOHN BLUE TANK SUB FRAME (A63291)
JOHN BLUE TANK SUB...
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2019 CHEVROLET...
Pallet Fork Extensions (A64047)
Pallet Fork...
2019 FREIGHTLINER M2 106 4X2 S/A 26FT  BOX TRUCK (A59912)
2019 FREIGHTLINER...
2016 Ford F-550 4x4 Venturo ET25KXX 2 Ton Crane Service Truck (A61573)
2016 Ford F-550...
