BuckhornMan
- Joined
- Aug 5, 2018
- Messages
- 2
- Tractor
- JD2630, Ford 5000, Ford 601, MF165
Hey folks,
Was getting equipment ready to make hay. The JD2630 had not been run in a while. Started right up and ran well, but immediately noted leak up around T-stat area. Shut it down. Much to my dismay I found milkshake on dipstick. Drained pan.....ugh!!
Have no reason to suspect HG leak....was never over heated. Really only use it to rake/tedder. Always has started and run well.
Not clear why it seemed to leak up near T-stat, although truth be told....not clear where leak source really was.
Tried to research other causes....found one possibility ....the oil cooler O-rings. Anyone out there have any thoughts?
Sure could use some assistance in getting pointed in the right direction.
Thanks in advance!
Thanks in advance!
