Coolant flush and fill
   / Coolant flush and fill #1
NewToy
Veteran Member
Ohio
'05 Farmtrac 270DTC
I replaced the coolant in the 270 today for the first time ever. I was looking at the manual and saw you are supposed to do it once a year or every 800 hrs. I had missed the once a year part, it's been almost four. I was expecting a mess when draining the old stuff but it looked very clean. I used Prestone flush and I figured it would be a mess but again it was clean upon draining. I flushed it a few times with water and refilled with FleetGaurd from TSC. I was surprised to see it was a purple color. My manual stated refill capacity was 5.5 qts and it took 7 to fill it. I was not surprised to find the discrepancy, when I did the 50 hr service all the refill cap's were off quite a bit.
John
   / Coolant flush and fill #2
I better get on that also. I haven't changed the coolant in my 270 yet either.
I changed oil and filter today. I used the Wix replacement filter for the Daedong filters I have been using. The Wix filter is larger (taller), like used to be on a car. It adds about .4 qts to the overall oil capacity, puts it right at 5 qts to middle of fill range on stick. The hood just clears the filter by 3/4 inch or so. I was sitting there looking at it while refilling oil and was concerned there wasn't adequate clearance, but it was fine.
John
2024 TOFT 1550 Hydraulic Breaker (A53117)
2024 TOFT 1550...
2006 GREAT DANE 48FT FLATBED TRAILER (A53426)
2006 GREAT DANE...
2019 Fontaine Traverse HT T/A 48ft. 41 Ton Hydraulic Dovetail Equipment Trailer (A52377)
2019 Fontaine...
2018 Mitsubishi Mirage ES 4D Hatchback (A53117)
2018 Mitsubishi...
Yale MPB040-EN24T2748 4,000lbs Electric Walk-Behind Pallet Jack (A51691)
Yale...
2000 Mack CH613 Day Cab Winch Truck (A53117)
2000 Mack CH613...
