coolant change
   / coolant change #1
bubbu55
North Creek N.Y.
Kioti CK35 HST
I own a 2008 CK35 hst anybody recommend a coolant that is above the rest? Also, do you mix yours with water or just use it without mixing?
   / coolant change #2
Haven't got to that point yet with my CK, But if you are not using a pre mixed anti-freeze and are blending your own, make sure to use distilled water. Under $1 at Wally World.
   / coolant change #3
Any extended life coolant will do. Mix is 60% coolant, 40% distilled water for max coolant protection. A richer mixture will degrade protection. A 50/50 mixture is likely the standard mix in NY since you don't get as cold as we do.
2025 GIYI GY-X380 Trencher Mini Skid Steer Attachment (A50322)
2025 GIYI GY-X380...
2025 Auto Darkening Welding Helmet (A50322)
2025 Auto...
2017 Ford F-150 Pickup Truck (A50323)
2017 Ford F-150...
2013 John Deere TS 4X2 Gator (A50121)
2013 John Deere TS...
2016 Hurricane Blo-Vac X3 Stand-On Blower (A50322)
2016 Hurricane...
