LS Tractor Owner
Super Member
- Joined
- May 1, 2017
- Messages
- 7,562
- Location
- Edgewood, NM
- Tractor
- LS XG3025 TLB, Previously MT125 TLB, Craftsman GTS6500
I have a substantial need to have a dump trailer. I have to "resurface" our stone driveway. It is unaffordable for us to have the stone delivered vs. me picking it up. I can get the stone at a discounted price of $12 / ton if I pick it up. Otherwise it's $20 /ton plus $85 delivery fee. (Approx 15 ton loads, so a total about $25-26 per ton). When time permits, I can go get a few loads and do a little at a time. It would take a while, needing about 150 tons. So....
I have a 4x8 utility trailer that was used to haul a 350 gal water tank (2800 lbs). It has a 3500 lb axle w/ leaf springs. My question is would it be cost effective to try and convert this to a dump trailer or apply that cost to a new "real" dump trailer. I haven't even begun to price out the pump/lift mechanism, figuring someone here has either done it already or found it wasn't cost effective.
I also have a 7x16' 7000 lbs dual axle trailer. My other thought was to build a "box" on this trailer to contain the stone. Then I would drive the tractor up onto the trailer to scoop the stone out. (Would definitely take longer, but it's seat time
) I can build a dirt ramp for the trailer or just use the ramps (more difficult due to the angle of the loading ramps)
The small trailer would only carry about a ton, the larger trailer maybe 2 tons, so cutting the amount of trips in half using the big one (that would be absorbed by taking longer to unload)
Any thoughts and input would be greatly appreciated.
