I'm sure this has been asked and explained plenty, but I'm not familiar with all of the proper hydraulic terms and i'm betting that is why I can't find the answer I want. What I'm doing is adapting a snow plow to use on the front of my tractor. I intend to use the loader controls to operate it, and my original plan was to use a pair of double acting cylinders - one for up/down and one for left/right angle. If I can utilize an existing plow frame and a pair of single acting cylinders (which I already have) for the left/right angle it will be easier than having to fab a new mount and get a new double acting cylinder. The problem is that if I plumb these lines directly to my loader valve's curl function ports i'm pretty sure it won't work - I've read a little and there seems to be a consensus that there is a regen function that will not allow this valve to control two single acting cylinders. My question is how do I get around this?
For reference I have a John Deere 770 with a model 70 loader. I know that there exists a factory option to do exactly what I want to do, because it is sold on the model 380 plow. If you look it up you will see a small fixture on the center of the plow frame that is taking in the hydraulic lines from the loader valve and sending out two lines that will control the left/right angle of the blade. I assume that this is some sort of relief valve that allows one cylinder to extend under power and allows the opposite cylinder to dump the fluid back. My question is: Is there some sort of generic universal hydraulic valve that will do exactly what I want without having to get a proprietary part from the manufacturer? Does something thing like this exist in the agricultural or snow plowing world that I can easily find (and if so, what is it specifically called, since I'm hydraulically challenged)?
I know that it will be simple and relatively cheap to just use one double acting cylinder to do the task, but it will be a bit more elegant and involve less fabrication and butchering to do this the way I want, so I'm hoping there is a not-too-expensive option to do this.
