Converting Generator To Propane
   / Converting Generator To Propane #1
s78wingrider
Hardy Co. WV
Mahindra 3215 gear
Thinking of doing it and would welcome any advice. Is propane hard on a gas engine? Thank You Aaron :confused:
   / Converting Generator To Propane #3
Not hard on a the engine at all. Another source is your local propane dealer, ours sells conversion kits for about every small engine you can think of. LUTT
   / Converting Generator To Propane #4
I think gasoline is far easier to obtain than propane. But, propane runs cleaner. I have heard that when you change the engine oil in a propane fueled engine, the oil often is still new looking.
   / Converting Generator To Propane #5
Some advantages/disadvantages with either one. LP stores better, but in very cold weather, it won't liquify from a small tank. Some claim that LP causes some HP loss on their generator or they get less running time from a 5 gal LP tank than they do with 5 gal of gasoline (I haven't noticed either of those, they seem the same on both counts)
I don't usually keep more than 10 gallons of gasoline on hand through the winter (but I do keep both vehicles topped off, just in case), but I do keep 4 20# and 2 30# LP tanks on hand and topped off prior to the winter season.
A few years ago, we had a freak windstorm roll through here and knocked out the electricity county wide, we had no electricity for 7 days, other parts of the county got theirs back after 3/4 days. None of the gas stations here had generators at that time, so they couldn't pump gas or even use debit or credit cards, but if you had cash or check, they'd unlock the cage and go the LP tank exchange route, but that's fairly expensive.
If you do buy one of the LP kits, make sure you get a dual fuel kit so you can run on either LP or gasoline.
   / Converting Generator To Propane #6
If your wanting to store fuel for a long period of time, go propane,
no road tax on propane (normally), and in our area much of the time the gallon of propane is 1/2 the cost per gallon than gasoline, yes there is about 10% less BTU per gallon,
for a "stationary" generator I think it is about the only way to go,
my larger generator starts so much easer when cold, and the fuel is more than 10 years old and as good as the day it was filled, and I still have the gasoline option,
I do have 1000 gallon tank, for the generators,
the small generator I have used a 5 gallon BBQ tank on it for portagle use, in the past,
Thanks Everyone for all the info! Aaron :D
   / Converting Generator To Propane #8
Many years ago (1989) when we became full time RVers, I had the dealer install a 4.5 KW Kohler generator in our fifth-wheel, and they converted it to LPG. I had read in RV magazines that you lost 11% of your generator capacity with LPG compared to gasoline. At that time, the dealer would have installed the 4.5 KW Kohler or the 4 KW Onan for the same price, so I figured the Kohler would give me more electrical capacity. I don't know that I needed the extra capacity, but at least we never lacked for sufficient electrical power.
   / Converting Generator To Propane #9
Propane, LP, (liquified propane) is stored under pressure and when it gets real cold (cold contracts while heat causes expansion) the tank loses its pressure.
That being the case at -30 (or so) you can't get more than 1/2 a tank of usage.
LP dealers love it as in the winter they exchange you a full (and charge for) a 1/2 full 'empty'. In effect they get to sell 1/2 a tank twice.
Also the higher the consumption the bigger the delivery line needs to be as freezing will occur.
We got around that 'scam' by not swapping but merely adding tanks. LOL, come spring we'd have a dozen 1/2 full tanks accumulated and do the swapping in the fall. Back then there were no deposits required on tanks and being inaccessible during winter we'd sled them ourselves. The dealer trusted us to return the empties at later date.
Tidbit of info: propane is about 120,000 BTU's per pound.
A propane engine at high mileage will be as clean and sludge free as the day it was made.
   / Converting Generator To Propane #10
That's a little high. It is closer to 91,500 btu's per gallon. And weighs about 4.2 pounds when the ambient temp is 60 degrees F.
2003 Volvo S60 Sedan (A53117)
2003 Volvo S60...
2017 Ford F-250 Crew Cab Pickup Truck (A51692)
2017 Ford F-250...
2018 Dodge Charger Sedan (A51694)
2018 Dodge Charger...
UNUSED JCT 72" HD BRUSH CUTTER (A51248)
UNUSED JCT 72" HD...
Pallet Fees (A50775)
2014 Club Car Electric Utility Cart (A51691)
2014 Club Car...
