converting deck lift hydraulics to a top and tilt
   / converting deck lift hydraulics to a top and tilt #1
brooksto
troutville,va
TYM 233, Kubota b2320, Simplicity Conquest, Cub Cadet slt1554, Ford lgt-12h
I have been thinking for a while on this one and would like to get everyones input. I own a TYM t233 with the mid mount mower. For various reasons, I have removed the MMM and do not intend to be using it anymore. Which leaves me with the two hydraulic cylinders and lines still attached to the tractor. This is operated by a lever under the seat that can be moved left to right to raise and lower the deck.
Would it be possible to use those existing lines and cylinders (or at least the control of them) to cobble together a 3 point top and tilt kit? I have done some searching and havent found anyone that has specifically done this, I have seen homemade kits but nothing using the existing mid mount mower controls to control a top and tilt. I realize it may not be the BEST solution, but with the lever control, lines, and cylinders already there, I feel like it may be a CHEAP solution and one that would greatly increase my productivity with my box blade. I would even be open to the option of just having a TILT function if I cant have both with the current control. Thanks for your comments.
   / converting deck lift hydraulics to a top and tilt #2
If you have a cyl spools on that valve, you can do it.
   / converting deck lift hydraulics to a top and tilt #3
Not sure what that means, but here's my take. Top and tilt requires double acting cylinders and a valve for each function. If that's what your deck raising apparatus has, then maybe it will work. I suspect it's only single acting and a single function.
2025 GIYI VR66 66in Vibratory Roller Skid Steer Attachment (A55787)
2025 GIYI VR66...
2016 Autocar Xpeditor T/A New Way Side Loader Garbage Truck (A55852)
2016 Autocar...
(4) UNUSED LANDHONOR PINS (A54757)
(4) UNUSED...
2007 Sterling Acterra Dump Truck (A51691)
2007 Sterling...
JOHN DEERE 1705/6700 LOT NUMBER 20 (A53084)
JOHN DEERE...
2004 Ford F-250 Liftmoore 2,700 LB 1 Ton Crane Service Truck (A55788)
2004 Ford F-250...
