Converting a bumper pull to gooseneck??
   / Converting a bumper pull to gooseneck?? #1
Backhoehoe
NE Oklahoma
2006 Mahindra 4530 with 511 backhoe/Kubota B-1700
Has anyone ever converted a bumper pull trailer to a gooseneck? I have a 20ft 15000# trailer that I would like to convert to a gooseneck. Does anyone know where I might find some info on this matter? Thanks--Bhh
   / Converting a bumper pull to gooseneck?? #5
I have a question...
For what reason are you doing this?
If it's because you have too much tongue weight or too much sway, try some equalizers and sway control. It makes a HUGE difference.
What do you plan to haul and how heavy?
I would be willing to bet your tires are not rated high enough to hold 15,000 pounds.
I say this because I have a 14K 20 foot trailer and have a family member who manufactured trailers for a living.
   / Converting a bumper pull to gooseneck?? #6
   / Converting a bumper pull to gooseneck?? #7
I think some of what you refer to is covered in that thread. I do know that you won't carry more weight just from the conversion. A 15,000# trailer is just that, regardless of the hitch.
You may be right about the tires. It's good to know the rating on them.
John
   / Converting a bumper pull to gooseneck?? #8
John
I am doing this because the gooseneck that I have is too large for most of the stuff that I use it for. I have two bumper pulls that are almost identical; one is 18' the other 20'. Both are well worn but good trailers. I am planning to convert the 20'. My truck is a F-350 4x4 with a elec./hyd. dumpbed; it has a hitch attached to the frame which is accessible through a door in the bed. It has a gas powered 460 auto with transmission braking. My other trailer is a 30 foot 3 axle flatbed implement trailer. I just replaced an axle on it and sure could have used a small gooseneck while it was broken. I would much rather use a gooseneck and hardly ever use the other two even for small jobs. Thanks--Bhh
Kelly Ryan Bagger (A50774)
Kelly Ryan Bagger...
Yale 50LX Cushion Tire Forklift (A49461)
Yale 50LX Cushion...
2012 Dodge Grand Caravan Van (A51694)
2012 Dodge Grand...
1988 John Deere 4250 (A50120)
1988 John Deere...
MoTrim 3pt. Arm Flail Mower (A50774)
MoTrim 3pt. Arm...
2016 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2016 Ford F-150...
