Converting 24 volt starter on JD730 diesel to 12 volt starter
   / Converting 24 volt starter on JD730 diesel to 12 volt starter #1
chas036
johnson city, ny
JD720D
Has anyone have any experience with converting a 720 or 730 Diesel from a 24 volt electric starter to a 12 volt starter, or replacing the pony motor with a 12 volt starter? If so, what type of starter and battery did you use, and what was your experience? In weather of 50F, did it turn the diesel fast enough to start it?
   / Converting 24 volt starter on JD730 diesel to 12 volt starter #2
:welcome: to TBN
What setup do you have now?
I have a 720 with no starter. It originally it had a pony motor, but my grandfather removed it years ago to rebuild it and never did, and he just pulled started it with his B when he needed it to plow or disk. I have it now and want to put an electric starter in it. I have all the electric start brackets I salvaged from a and old 720 in a junk yard, so all I need is the starter.
   / Converting 24 volt starter on JD730 diesel to 12 volt starter #4
There is a starter shop that advertises in Green Magazine . What are you doing for batteries ? Where is the starting engine now ? Most just need the fuel system cleaned and a set of coils .
(INOP) CASE IH MAGNUM 180 TRACTOR (A50459)
(INOP) CASE IH...
Adams 8 Ton Weigh Hopper (A51039)
Adams 8 Ton Weigh...
2015 WESTERN STAR 4900 SF (A50854)
2015 WESTERN STAR...
2024 BCL Fabrication Landscape Dump Trailer - Heavy-Duty Utility Trailer for Mulch Debris Hauling (A51039)
2024 BCL...
2005 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2005 Big Tex 10PI...
2000 John Deere 770CH Articulated Motor Grader (A49461)
2000 John Deere...
