Converting 13hp pressure washer for Dual use
   / Converting 13hp pressure washer for Dual use #1
goodoleboy
USA
Still looking since thats half the fun!
Im sure anything is possible with enough money. I would like to convert my pressure washer w/ 13hp honda GX engine into a dual use machine.
Im thinking take the pressure washer pump off, then using the engine to power a generator by bolting up the generator parts.
The engine is a horizontal shaft, Ill try to find exact specs like serial number and shaft length.
Anyone with knowledge please respond.
   / Converting 13hp pressure washer for Dual use #2
Just an idea but you maybe able to use the water in a closed loop to spin a typically hydraulic generator. You could possibly even try running oil in it instead.
   / Converting 13hp pressure washer for Dual use #3
Ariens used to sell a Motor-based unit that could be a rototiller, a generator, a compressor, etc. depending on what you attached. Just pick a standard shaft coupling and mounting system and you're in business.
2011 DOOSAN G25 GENERATOR (A53843)
2011 DOOSAN G25...
2014 FRAC TANK (A53843)
2014 FRAC TANK...
FIRESTONE 9.5L-15 4 RIB TIRES (NEW CONDITION) (A55301)
FIRESTONE 9.5L-15...
2019 FREIGHTLINER SPRINTER 2500 CARGO VAN (A54313)
2019 FREIGHTLINER...
2017 GMC SIERRA 1500 (A53843)
2017 GMC SIERRA...
