rob in ore
I have a Montgomery Wards gas powered wood splitter from the 1980's. This is the type that uses the reservoir as a trailer for towing it around. The original engine was replaced/upgraded about 20 years ago. Now that engine is showing its age too. The other components are holding up fine. When the engine finally gives out, I'm wondering about converting the unit to mount on a 3 point and use the pto to power the pump. I'm sure I have the horsepower for the pump so I'd rather use the pto than tap into the hydraulics. I doubt my tractor has the hydraulic flow to run a splitter with hydraulics alone. Also, the splitter uses automatic transmission fluid and I don't want to risk mixing that with my tractor fluid.
I know I'll need to build a frame to mount on the 3pt. The new unit would need to be mounted to the tractor while in use. After that is it just a matter of lining up the shaft so it's straight? Should I change/upgrade the pump at the same time? What calculations do I need to consider for sizing the pump to the cylinder/valve/reservoir? Is it possible to have too much power from the pto?
