Convert Trac Vac 560 to PTO operated ?
   / Convert Trac Vac 560 to PTO operated ? #1
snpower
Charlottesville, Virginia
John Deere GT235, GT 275, 1025R
Wondering if anyone has done this, or knows that it is possible? I saw a Trac Vac PTO unit for sale on Ebay - minus the cart - which made it more affordable ($450.00).
   / Convert Trac Vac 560 to PTO operated ? #2
There are several threads on pto powered lawn vacuums. If your eliminating the gasoline engine why are you buying an expensive frame that has to be remodeled ? If you have the capabilities of welding and cutting buy the housing / impeller from a walk behind unit. They are available for fifty to seventy five dollars, sometimes even free on CL. Some bearings, shafts, pulleys and a section of eight inch hose... and don't forget belts. I built one for $150.00 and it works great. The scavenger hunt for parts is the most fun besides testing the actual product. Take a look under build it yourself forum and get some ideas. Before you know the creative mind has it built before the first piece of metal is cut. A real fun satisfying project. Good luck and looking forward to your version with of course pictures.
PS... We need a picture of the puppy. My assistant is a soft coat wheaten terrier.
2022 Gulf Stream Kingsport 248BH T/A Travel Trailer (A48082)
2022 Gulf Stream...
Peterbilt 377 Semi-Truck (A51039)
Peterbilt 377...
Ranch King Gooseneck Trailer (A50860)
Ranch King...
2015 Ford Transit 250 Cargo Van (A48081)
2015 Ford Transit...
(1) Push Blade and (1) Disk (A50860)
(1) Push Blade and...
2015 Ram 1500 Crew Cab Pickup Truck (A48081)
2015 Ram 1500 Crew...
