convert propane to gas in case 811b
   / convert propane to gas in case 811b #1
DrRick
san angelo, texas
dk55, jd 450,case 811b,kioti mechron,farmal cub & super c
I was wondering if anyone knows the best way to convert my case 811b from the propane setup , back to a carburetor and gasoline setup? It works well but the propane filling is a bit of a hassle and the power would increase I have heard. Where would be a good place to look for a carb, as I can get a fuel tank.
rick roberts
   / convert propane to gas in case 811b #2
Here are the carb part numbers used on the gas 811's. You'll just have to figure out which one fits your application.
I Googled the part numbers, and new one's look to run from $255.00 to $280.00. I did see one on Yesterday's Tractors ads. A new one, and the guy will take $125.00 for it. But not sure how old the ad was.
I checked manifolds, and unless I missed something, they appear to be the same. The LP models do have the vaporizer though.
I found these part numbers on Ford/New Hollands parts site. Thought for sure they would be on Case/IH, but wasn't... Just for giggles went to F/NH and there it was. Just typed in 811 for the model #.
Hope this helps..!!
C0NN9510G CARBURETOR Carburetor Assy., 172", After S/N 126524, This Carburetor Assy. Does Not Use Ref. 2 thru P/N CAPN9590D Repair Kit, Start Year: 01/01/1960
1 1 B8NN9510A CARBURETOR Carburetor Assy., 134", This Carburetor Assy. Does Not Use Ref. 2 thru P/N CAPN9590D Repair Kit, Start Year: 01/01/1958
1 1 B8NN9510B CARBURETOR Carburetor Assy., 172", Before S/N 126525, This Carburetor Assy. Does Not Use Ref. 2 thru P/N CAPN9590D Repair Kit, When Using This Carburetor on Older Units, M
   / convert propane to gas in case 811b #4
shouldn't be a bad swap.. probably at most a carb and perhaps manifold and specific throttle and governor linkages.. and of course the fuel tank and lines.
I have a ford 951 that was originally on propane and is now a gasser. still has the old propane warmer built into the cooling system.
soundguy
2020 Nissan NV200 Cargo Van (A51692)
2020 Nissan NV200...
MASSEY FERGUSON 492 TRACTOR (A51406)
MASSEY FERGUSON...
7021 (A50322)
7021 (A50322)
2020 GP Equipment 24in Excavator Bucket (A51691)
2020 GP Equipment...
2015 John Deere Z950M 70in Zero Turn Mower (A51691)
2015 John Deere...
