Convert mulcher to side discharge?
   / Convert mulcher to side discharge? #1
JDgreen227
Super Member
Central Michigan
4210 MFWD Ehydro--'89 JD 318
Just purchased a used Craftsman 6.75 torque Briggs self-propelled pusher for $50, low hours, starts and runs fine. Only issue is that it is a mulcher/bagger deck and I want to convert it to a side discharge and install a plastic discharge chute from an older mower. Has anybody ever tried this kind of conversion and is it worth the work involved? I just wonder if the deck on a model like this would be manufactured for airflow and discharge out the back and might not side discharge properly. Thanks for any input.
   / Convert mulcher to side discharge? #2
From what I've seen of the rear discharge mowers, it would be hard to make a side discharge out of it.........but it could be attempted.
Follow the contour of the 'chute gathering' on top of the deck, and compare that to a side discharge.
You will normally find a deeper 'well' in there to facilitate the vacuum created by the blades, to keep the grass clippings at a greater height to make up for the longer distance.
One could..........basically 'cut-off' the chute flow to make a side discharge( side discharge mowers do have this 'cut-off' point), just takes some fabricating.
I don't think it is worth the work involved, but people have done things that are a lot more complicated than your issue.
Freightliner Tender Truck - Adams Tender (A55301)
Freightliner...
GMC 3500 Extended Cab 4WD Pickup Truck - 6L V8 Gasoline Automatic (A55218)
GMC 3500 Extended...
2016 John Deere 326E (A47477)
2016 John Deere...
2025 JOHN DEERE 408R LOT NUMBER 10 (A53084)
2025 JOHN DEERE...
2020 CHEVROLET SILVERADO TRUCK (A51406)
2020 CHEVROLET...
2021 CATERPILLAR 926M WHEEL LOADER (A52705)
2021 CATERPILLAR...
