Convert Generator to NG and Electric Start
   / Convert Generator to NG and Electric Start #1
TimberXX
Platinum Member
Bergen County, NJ
BCS 770 Italian 2 Wheel Tractor, Grillo 107d, BCS 853, Deere x350, Deere x730
My dad has a Briggs and Straton Generator. It has no frills, but gets the job done. It has about 150 hours on it in 8 years.
He can't pull start it anymore, can a shop add electric start?
In the northeast power outages rarely take out natural gas. I know he would like the generator to run on both natural gas and gasoline. Is there is kit for this motor?
Does the generator assembly need any maintenance? I thought it was maintenance free, but I am not sure.
The Briggs engine family is YBSXS.3052HT 274499
Thanks Guys.
   / Convert Generator to NG and Electric Start #2
Check out this web site... Briggs Stratton Engines Family Numbers I bought a kit from them last summer and installed in on my Generac with no problems.
I bought the tri-fuel kit since I wanted to use it with propane and gasoline backup. Propane doesn't "go bad" as does gasoline and it takes fewer pulls to start. Sounds like you would be connecting to NG which should yield good results although it might limit where you can place the unit.Can't help you with a conversion to electric start.
Licklog
I am sure that someone knows if I can add electric start to this engine.
Please help!
   / Convert Generator to NG and Electric Start #4
call a local lawn mower service and give then the engine numbers. they will be able to help you and give you prices too. zman
CROSSTECH 4200X 57" HYD BRUSH CUTTER (A51406)
CROSSTECH 4200X...
CAT 973 Crawler Loader (A47477)
CAT 973 Crawler...
2022 Toro Workman 07921 Electric Utility Cart (A54811)
2022 Toro Workman...
Honda EU3000is Gasoline Companion Inverter Generators (A54811)
Honda EU3000is...
2000 FORD F450 SUPER DUTY SINGLE CAB FLATBED TRUCK (A51406)
2000 FORD F450...
2013 XLR THUNDERBOLT 35X14 5TH WHEEL CAMPER (A53843)
2013 XLR...
