Convert gas generator to propane???
   / Convert gas generator to propane??? #1
zimcocomp
West Newfield, Southern Maine
Kubota L2550 4wd, & Bolens QT 16, w/ Diy FEL
Has anyone had experience converting a gasoline powered generator to propane?
I have a Generac 10000EXL using a 19 HP GN-570 gas engine and I am looking into
a conversion kit to run it on propane to eliminate the old fuel problem. Has anyone
had experience in doing this and where can you get the best kit for the best price?
   / Convert gas generator to propane??? #2
yes I converted my generator, actually two of them,
I used the TRI fuel kit, as I wanted to keep the gasoline option, (problem is the change with the LP unit added change the unit such it is nearly impossible to get it started on gas, it will run on gas once started, the other generator, I used a fork lift LP conversion kit I got off of Ebay on it, it is a larger multi cylinder engine,
I ordered the additional Safety Shut Off, as I have a generator shed, I do not remember which company I ordered from,
Generator Conversion Kits to Propane and Natural Gas.
Generator Propane Conversion Kits & Natural Gas Conversions
an electric start would make starting easier, as they work on vacuum and you have to push a pin to let propane flow for a given set of seconds, (like priming it) and pull the rope. Safety shut off your pushing two pins, with electric start, it just makes it easer as you crank it and push the pin, and she runs, ,
usually with two quick pulls, once one gets it figured out it starts reasonable easily.
and on the larger generator, it starts very easy with the electric start,
(In theory to properly set the carburetors, one need a meter that reads the CO. of the exhaust, on the larger engine I know I did, do not remember on the small 8 HP motor.
follow the info from the manufacture and you will most likely have a good conversion,
I think if I was doing it again on my small generator I would get the propane carburetor that replaces the gas carburetor and set the gas unit aside for use if ever needed, and not go with the dual or TRI fuel set up,
   / Convert gas generator to propane??? #3
I recently converted my 13-year-old 10 HP Tecumseh powered portable generator to propane using the tri-fuel kit. The conversion was fairly easy. Runs better on the propane than gasoline. It is a little harder to start using the propane. Takes about 5 pulls. But I think the reason is that I've not yet figured out the correct method of priming the engine. I just bought a 100 pound propane tank to be my emergency reserve fuel. My local TSC charges $1.99 per gallon for the propane. Seems like a good deal.
I read somewhere that electric start is recommended but not required. With that in mind I did not do the conversion until I confirmed via youtube video of someone doing the conversion with manual start generator. I've not had any problem getting it started.
I haven't attempted to run the generator with gasoline after the conversion. The instructions recommend removing the propane hose and plugging the regulator inlet to avoid a vacuum leak before running on gasoline. I just bought a plug yesterday.
I wanted this conversion because I figured in a real emergency it might be easier to get propane than gasoline. And I still have the option on using gasoline. Plus propane does not degrade like gasoline when in long term storage.
   / Convert gas generator to propane??? #4
Just be aware that the rate propane will vaporize is very dependent on outside temp and surface area of the propane in the tank. According to the Yamaha web site their 7kW genny needs a 400 gal propane tank to provide enough surface area for it to power the genny with temp at 20F.
This past yr I purchased a used Honda genny with maybe an hr on it and it came with a propane conversion. Since the only propane tanks I have are the port 20# and the larger one on the motorhome, the first thing I did was remove the propane setup. Forget right now but there was something about the conversion that wouldn't let me run the genny on gasoline with the propane conversion in place. Seems like it was the choke wouldn't work. About the only time we loose power here is during the winter. I'm not willing to take a chance a small propane tank can't get the job done when I need it.
Now if you have a large propane tank with a wet leg or a buried tank, there are ways to make the conversion work with smaller tanks.
Here's a link I just looked up. Since I pulled the propane conversion off my genny I've not paid much attention to needed tank size.
Care and feeding of Propane Fueled Generators ォ Engineering Radio
   / Convert gas generator to propane??? #5
mine small generator has a 8 hp motor and would use the generator on my truck to run a drill fill auger, and a 20 pound bottle ran it OK,
was not loading it much, and it was above 45 most of the time,
when the propane expands, it cools and can cool enough to limit it ability to vaporize properly, (on the big generator, it uses liquid propane and then a vaporizer, that is heated by the coolant)
at negative 40 propane will not vaporize,
Just a follow up from my idea of conversion back in 2013. Completed the conversion back then and I must say I have had no problems of any kind. It starts and runs quite well even down below -10 degrees. Even with a 100 lb. tank. I used to have carb problems fairly often if it didn't get started often.
   / Convert gas generator to propane??? #7
Little shot of "starting fluid" done carb throat may make it easier to start.... Personally I use carb cleaner, its not as volatile as ether but a little more pizazz then propane, so not quite as much of a shock in engine internals...
   / Convert gas generator to propane??? #8
A issue to consider is propane has lower BTU (octane) than gasoline so you will loose a bit of the power generator is capable of (some thing like 8-10%) so be sure your load is below "new" lower power out put....
   / Convert gas generator to propane??? #9
BTU (energy content) is NOT the same as Octane. The octane rating has no direct link to energy content (For example, ethanol has higher octane than gasoline, but lower energy content.) However, you are otherwise correct: propane has lower energy content than gasoline.
   / Convert gas generator to propane??? #10
Octane rating is not related to BTU.
2019 WYLIE EXP-500S WATER TANK TRAILER (A45046)
2019 WYLIE...
2022 Down2Earth 82in x 34ft Two-Car Hauler (A44789)
2022 Down2Earth...
52" Toro Dingo Bucket (A42021)
52" Toro Dingo...
Pickup Instructions (A42021)
Pickup...
2015 FREIGHTLINER CORONADO 122 SD (A45333)
2015 FREIGHTLINER...
2008 Ford F-150 Pickup Truck, VIN # 1FTPW04598KC49674 (A44391)
2008 Ford F-150...
