Hi All,
I'm thinking of setting up a electrohydraulic system to add further ports to my machine. I've learned a fair bit so far but I'm missing a few key points. The biggest one I have is if there is a 'circuit board/controller module' between the joystick and the proportional control valves, or if it is a direct electric connection between the joystick and valves???
The other big question is cost. Am I dreaming to think that this will be reasonable at all?? I realize that this set up will not be cheap, but neither is the diverter valve option. If I could get it up and going for 2-3 grand, I'd be in the same ballpark as the JD diverter kit + WR long thumb switch, plus I'd have featherable circuits that are always available rather than have to fumble with switches.
Otto engineering sells a huge selection of joysticks and Hall Effect switches that allow for proportional control of hydraulic circuits. In an ideal world I'd like to add a new grip to my existing FEL lever that has a 'top hat' button to control my top n' tilt, a sliding thumb switch for a grapple, an on-off push button that'd control a PTO driven high flow circuit to the FEL for a snowblower or broom, and a momentary button for a horn (and a trigger for missile lock.....).
I'm going to try and get a hold of Otto in the new year to see what they have to say. Their website says they work with everyone from single unit users to companies that'll buy 1000's at a time.
-Jer.
