controls are locked. Need help. Is there a seat safety switch in the KX121-3?
   / controls are locked. Need help. Is there a seat safety switch in the KX121-3? #1
KX121
Saratoga Springs
kx121-3
I really need advice here! My Kx121-3 is locked up on a jobsite. I pulled the lever up on the left as always to get out of the cab and my shirt caught the lock lever and pulled it down. I got back in, pulled lever up, then down to engage, and controls are LOCKED. Engine runs, turns on/off fine, etc. The lock lever is only recognized as being in the locked (UP) position no matter if it's up or down.
   / controls are locked. Need help. Is there a seat safety switch in the KX121-3? #2
Contact Dealer.... is the only thing I can think of.
   / controls are locked. Need help. Is there a seat safety switch in the KX121-3? #3
You may have bumped one of the interlock switches out of line when catching the shirt. On my BX I was amazed by the flimsy way some of them are installed. Had several get out of line over 1500 Hrs.
Ron
   / controls are locked. Need help. Is there a seat safety switch in the KX121-3? #4
On my 6530 there is a pin on the side of the joystick.
On a friend's 4052 JD it's on the side, just below the mid point where your right leg would be when sitting in the seat.
Got an owner's/operator's manual. Should call it out in there.
AT 26" x 11-12" (A52377)
AT 26" x 11-12"...
2022 John Deere 410R Sprayer (A53342)
2022 John Deere...
2025 New/Unused Wolverine Hydraulic Skid Steer Pallet Forks (A51573)
2025 New/Unused...
49" X 74" EXPANDED METAL RAMP GATE (A51247)
49" X 74" EXPANDED...
2014 Ford Taurus AWD Sedan (A51694)
2014 Ford Taurus...
Turfco Mete-R-Matic III Pull-Behind Top Dresser (A51691)
Turfco...
