santacruzer
Bronze Member
Hey guys,
I could sure use a little feedback here. I'm working out of a workshop manual so I think I have the facts correct.
The "control valve" on my 2008 BX 2350 Kubota (95 hrs) is leaking big time. "Control valve" is a fairly vague term in my mind, but it is the valve(s) directly under the joy stick that control(s) the entire FEL and boom operations and 3 point hydraulic system. It is sort of a manifold with "ports" that feed the hydraulic lines going to the different action points of the FEL, boom and the 3 point.
At first the 0 rings in some of the valves in some of the ports leading to the FEL started to come apart in pieces as if they were torqued too tight and gradually fell apart.
The tractor was sent ot the shop (Kubota dealer) and it was determined that the original 0 rings were the wrong size. The "correct" 0 rings were installed and all seemed fine...for awhile.
The replaced 0 rings are starting to lose their integrity again (popping up as if they were torqued too tight) and are not leaking yet but soon will I suppose.
Now, there is a big hydraulic leak in one of the ports leading to the 3 point. I can't see exactly where (I'm not going to disassemble anything to find out).
But I know it's something in the 3 point valve(s) because lifting the BB really pushes the fluid out.
I know that Kubota is responsible and it will eventually get it fixed. My question to you all is; has anything like this ever happen to your machine...do you know of anybody who has.
I asked the shop foreman, one of the mechanics and the sales guy who is pretty savey, "how many of these "control valve" leaks do you get?".
Everybody at the dealership said they have never seen it before. They have never heard of it before. Now this is a large, reputable and established tractor dealership.
I can't say "you gotta be BSing me" but I have a hard time believing that I have the first Kubota that the "control valve" went south.
I know this is sorta long but any info I can gather will help me out. I'm not a professional mechanic and I don't like to engage in technical discussion with a dealership. So I think a little background from you guys will help me a lot.
Many thanks. Paul
Many thanks. Paul
