3-Point Hitch control of PTO whule mowing
   / control of PTO whule mowing #1
Jamucat
Halfmoon Bay BC
L-1501 Kabota Bobcat 763
I have a new 5 ft rotary mower deck. This is my first experience with the PTO in use. Kabota L1501 DT (L185)
The question is this. Seems that it is not possible to stop and change gears Ie reverse until the mower spins down. When the clutch is pushed in the PTO starts to slow down but the transmission can not be shifted until the PTO has stopped. Is there any thing I am missing? Just don't want to get into any corners I guess.
Charles
   / control of PTO whule mowing #2
I assume you're throttling all the way down before disengaging PTO. That will slow it down most of the way and if you're still in grass just drive a few feet and it will stop. I have an HST, but I'm guessing the PTO on yours keeps the transmission spinning so the gear change can't be made without grinding.
Thanks for the tip throttle down and make mower work to slow even faster.
That looks like it will really solve a big problem for me. Thank you
Charles
I have contacted the dealer where I bought the mower deck and they want me to but a new PTO shaft with he clutch built in. It looks to me that the clutch shown in the above link should be able to just be placed between the PTO shaft out put and the PTD drive shaft. I might have to shorten the shaft a bit but that would be cheaper than the one from the dealer. Any thoughts on this?
Charles
   / control of PTO whule mowing #7
We just shortened the PTO shaft on our mowers, I don't know why you would need to buy a new shaft.
JOHN DEERE 9650 COMBINE (A51243)
JOHN DEERE 9650...
2018 INTERNATIONAL 4300 26FT BOX TRUCK (A51219)
2018 INTERNATIONAL...
CATERPILLAR 303.5C CR EXCAVATOR (A51242)
CATERPILLAR 303.5C...
2021 John Deere 333G Two-Speed Hi Flow Compact Track Loader Skid Steer (A50322)
2021 John Deere...
2006 CATERPILLAR 330DL EXCAVATOR (A51242)
2006 CATERPILLAR...
2008 Kenworth T300 T/A Knuckleboom Crane Truck (A50323)
2008 Kenworth T300...
