Continuous Flow Switch on 4th / 5th Hydraulics?
   / Continuous Flow Switch on 4th / 5th Hydraulics? #1
LouieJunior
Platinum Member
Moline, Illinois
JD4052R Open Station
I am questioning weather I need to include Power Beyond (to supply my 3 point log splitter), if I have ordered the 4th and 5th rear remotes on JD 4052R open station tractor. Something I saw earlier leads me to now believe the 4th or 5th SCV have a switch for continuous flow. Can anybody confirm this? If so, is it another option -- or standard?
   / Continuous Flow Switch on 4th / 5th Hydraulics? #2
Yes, if you have the 4th and 5th rear remotes you will have continuous flow to one of the valves. You engage the appropriate lever, can't remember which one, and activate the switch and you have continuous flow. I have a 3 point log splitter I use on my 4066r (cab model) and it works just fine.
Thanks TC -- that'll save me between $300 and $400! Plus, I will be able to raise and lower my 3-Point Hitch while operating the log splitter. (not do-able with the power beyond approach).
Pallet of (5) 8 Lug Misc Wheels (A48837)
Pallet of (5) 8...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A49346)
2025 Kivel 48in...
PECAN BLOWER W/ FULL SHAFT (A50459)
PECAN BLOWER W/...
(38) TRUSSES - 24" X 12' (A50460)
(38) TRUSSES - 24"...
Airco Tig Welder (A49346)
Airco Tig Welder...
METAL FUEL TANK (A50459)
METAL FUEL TANK...
