Contemplating an electric go-kart as a small yard cart puller
   / Contemplating an electric go-kart as a small yard cart puller #1
ning
Elite Member
Northern California
Branson 3520h
My wife does a lot of weeding, trimming and pruning, and generates a lot of yard waste; this gets put into a simple garden cart (10 cu ft) which is currently pulled behind our aged lawn tractor.
That lawn tractor as noted is old, and it's noisy, stinky, and lots of starts and stops just moving the cart a bit here and there is tough on its battery.
I have in mind something electric (battery EV) that can pull it around the land; that would allow her to move the cart fifteen or fifteen hundred feet to the next work spot if she wants with no bother about starting it, worry about leaving it running because it's just a quick stop or not, etc.
Range is a very low requirement - we've got 8 acres and this thing really only needs to do a few loops of the land at the most between charges - like, a mile - so it doesn't need a lot of battery capacity, and it definitely doesn't need a lot of power - just a nicely geared-down drive system that allows say 1-5mph speed. The land is bumpy enough that I don't expect it to need to go much faster than that.
Those requirements, of course, rule out pretty much everything on the market. An electric UTV with a dump bed would be pie-in-the-sky ideal, but they're way bigger than we want (one person capacity and narrower would be better) and have way more capability (30+mph, miles and miles of range) and way way way more cost.
I'll deal with dumping the cart instead of a dump bed, and the rest of the unit... I've been coming to basically an off-road go cart, converted to electric, with a welded-on trailer hitch. Probably gear it way down in the conversion process, which should make pulling the trailer trivial (the trailer never gets more than a hundred pounds anyways, and she's light, and I'm not particularly heavy either if I need to use it). The low-slung nature of a go-kart, with bigger wheels & tires on the off-road version, is appealing for stability as well.
Anyone here play with off-road go carts much? I see some cheap electric versions, but they seem really small even the "for adults and teenagers", though it would probably be fine for my wife. Still wouldn't mind something slightly bigger...
This is probably one of those "someday I'll do this" projects.
   / Contemplating an electric go-kart as a small yard cart puller #2
I wonder if one of the battery powered riding mowers would do the trick? They are limited in speed and range (though that gets probably gets better if you are not mowing.) They are a whole lot less expensive than electric UTVs.
   / Contemplating an electric go-kart as a small yard cart puller #3
Golf carts are convenient and have their place.....start saving now for when you have to replace all batteries.
   / Contemplating an electric go-kart as a small yard cart puller #4
HiSun Sector E1. $12-13k. Winch, roof, windshield, hitch receiver all standard. Dump bed. 4WD.
I use ours to pull our 14' trailer all around our 20 ac. About 40 miles per charge, so every couple of weeks. Regular AC plug.
Negative is it is Chinese. Assembled in McKinney, TX.
We did have a problem with the charger initially. They ended up replacing the UTV and resetting our warranty in writing.
   / Contemplating an electric go-kart as a small yard cart puller #5
My 48V Lithium powered AEV Super Cart has a truck hitch on the back, carries a lot of stuff, and even people with the rails lowered. I can yank a dual axle trailer with 48 bales of hay on it up an include with only traction being the issue. Better tires solved that problem.
   / Contemplating an electric go-kart as a small yard cart puller #6
I also use a standard golf cart for around the property. I have turf style tires that give more than adequate traction.
   / Contemplating an electric go-kart as a small yard cart puller #7
   / Contemplating an electric go-kart as a small yard cart puller #8
We as well use our electric club car as a runabout on the acreage. works great and pulls our little dump trailer with ease.
   / Contemplating an electric go-kart as a small yard cart puller #9
I sold my golf cart a couple years ago before we moved to our current property and am sorry I did. A lot of what I do with a UTV could be done with less lawn damage with a golf cart.
Way out of the price range, but sounds cool.
Love it - also out of the price range.
How about something like this:
Suspect it would fall over on 90% of the land.
That's probably closest to what I'm thinking about, though I'd be concerned about the gearing as my gas lawn "tractor" already has some issues pulling the trailer when it's loaded up a bit (not that it gets particularly heavy, but there are hills here).
I had figured getting an off-road go-kart frame and basically building an electric go-cart... something like the "yerfdog". Select gearing to make it really slow and super torquey.
Benefits would be, very low to the ground so especially on the upper garden "road" which barely qualifies for the name because of large rocks (boulders? bedrock? I tried to dig & pull them out but I think I'd need to blast it) embedded it would let her feel confident that it won't roll over - and anyway that yerfdog has effectively a roll cage (which I personally wouldn't want to test, but at 3-5mph should be ok)... light weight build with no extras, no expensive OEM battery packs.
2014 Ram 1500 Pickup Truck (A56858)
2014 Ram 1500...
2008 BMW 535xi AWD Sedan (A56859)
2008 BMW 535xi AWD...
2012 PROCO 130BBL VAC TRAILER (A58214)
2012 PROCO 130BBL...
2008 Komatsu WB146-5 (A55272)
2008 Komatsu...
84"X18' DOUBLE AXLE TRAILER (A58375)
84"X18' DOUBLE...
UNUSED FUTURE XGJ 40" HYD MINI ROTARY TILLER (A58376)
UNUSED FUTURE XGJ...
