Backhoe CONSTRUCTION KING CASE 580B
   / CONSTRUCTION KING CASE 580B #1
babydaniel
wanneroo
construction king case 580b
I have a Construction King Case 580B backhoe and I bought a manual for it but was send a manual for the 580C - would they be the same or similar
Andrew
   / CONSTRUCTION KING CASE 580B #3
Andrew, I have a 580B and correct manuals, and in searching out parts there seem to be a few things that MAY be different between B and C models -
Equipment Parts Source ( Equipment Parts Source, Aftermarket, Case, Backhoe, Crawler, Loader, Dozer, Tractor Home Page ) has been a good source for cylinder repair kits, but you MUST know which cylinders your particular machine uses, which requires teardown of at least ONE of them BEFORE you order (Don't ask how I know) - Case used at least two different diameter cylinders on the hoe boom on the B's, plus one piece or split pistons, etc - same with some starter parts and probably others.
John's link (thanks, John) looks like a good resource, now bookmarked :=)
HTH... Steve
   / CONSTRUCTION KING CASE 580B #4
Andrew, I had that issue with a front end loader. Most info was relevant, however some minor things were off.
1993 HEIL TRAILER INTERNATIONAL FUEL TRANSPORT TRAILER (A52472)
1993 HEIL TRAILER...
2015 DODGE RAM...
2022 Bobcat T66 (A50120)
2022 Bobcat T66...
2015 Peterbilt 320 Heil Front Loader Garbage Truck (A50323)
2015 Peterbilt 320...
2017 Chevrolet Express Van, VIN # 1GB0GRFF9H1305955 (A51572)
2017 Chevrolet...
2020 Utility Trailer Manufacturing, 53' Trailer (A52384)
2020 Utility...
