Considering the purchase of a JD 5300
   / Considering the purchase of a JD 5300 #1
elginfarm
Bronze Member
Southwest suburb of Chicago Area
JD 4400
Hi everyone,
I am considering the purchase of a 1998 JD5300. It has approx 1500 hrs on the meter. It is equipped with a loader and turf tires. The machine was stored outside so it is a little weather beaten. The two rear remotes control the loader. ( is this normal?) It also has power beyoind. The Trans is the 9/3 collar shift. My use for this machine would be mostly for mowing and baling hay. THE only loaderwork I would dois what my 4400 cut couldn't handle. I gladly welcome any advice or opinions on this machine from those of you with experience with this type of tractor as well as pricing information.
Thank you,
Eldon
   / Considering the purchase of a JD 5300 #2
If the 5300 is MWFD it will out lift & out work the 4400. Rear remotes are normal with hoses running to the loader. I mow & bale with a 5200. It has enough weight to bale and pull the bale wagon behind the baler. Saves a trip and lots of effort. I would get ag tires though.
2004 Hydraulic Breaker Excavator Attachment (A49461)
2004 Hydraulic...
John Deere 16 Row Cultivator (A50514)
John Deere 16 Row...
1995 KOMATSU WA320-1 WHEEL LOADER (A51242)
1995 KOMATSU...
2019 HONDA PIONEER 5 1000 UTV (A50459)
2019 HONDA PIONEER...
2021 Caterpillar 304E2 Mini Excavator (A50322)
2021 Caterpillar...
Unused 2025 CFG QNT50R Mini Excavator (A49461)
Unused 2025 CFG...
