Considering L3400 / Quotes
   / Considering L3400 / Quotes #1
Elliott Wave
Bronze Member
Massachusetts
Kubota L3400 HST
Hello,
I have been reading this Forum off and on for a number of years and regularly for the past year. I am considering purchasing a L3400 HST or DT. I am looking to use the machine as a TLB. For the first couple of years it would primarily be used around a 2 acre piece of property to dig and maintain some drainage ditches, dig out some stumps, maintain trails, load snow that is not conducive to snow blowing, and just have fun messing around with. It by no means is actually needed. That being said, I would like a machine large enough that if down the line I bought a trailer I could do some weekend landscaping type work. I would like to store the tractor in a garage that has a door height of approximately 79? I would purchase the Woods BH80-X for the tractor. Based on the Transport Height listed in the Woods brochure (82.25?, it looks like I would have to both adjust the backhoe and lower the ROPS each time going in and out of the garage. I am curious if anyone stores a tractor this way? I know if I went with the B7800 or B3030 and put a BH70-X on it, it would store easier as the Transport height listed is 74.75? However, since I am not looking at using the tractor for mowing I have been leaning toward the L-3400 and the larger hoe along with the swing speed control that comes with the BH80-X. I would go for the B-26, if I had a taller place to store it
While I am not planning on using any three-point attachments initially, I do not want to rule them out. In reading the issues regarding the PTO, 3-point hitch valve, and PTO cable it seems they have all been resolved in the newer models after certain serial numbers. My initial inclination was to go with the DT model as the DT was the original design for this tractor when it came out and less issues seem to have been noted. However, most seem to recommend the HST. I have not test drove either yet. Since I will not be using the 3-point hitch initially, can the items of concern be tested to make sure they work properly without an implement attached?
I have visited two dealers for initial price quotes (DT models are $1000 less):
Dealer A (35 miles from home)
Kubota L3400 HST with LA463 Loader with skid steer quick coupler $18,300
Loaded rear tires included in price
Woods BH80-X with Mechanical Thumb - $7,650
Block Heater, weld on hooks for loader, woods tooth bar - $549
Will charge for pick-up and delivery of tractor for warranty items
Dealer B (50 miles from home)
Kubota L3400 HST with LA463 Loader $17,900
Woods BH80-X with Mechanical Thumb - $7,300
Block Heater, weld on hooks for loader, ATI toothbar with replaceable teeth - $555
Will not charge for pick-up and delivery of tractor for warranty work for the first year
Dealer C (25 miles from home)
Have not spoken to yet, not sure if I am comfortable with service department
Dealer D (70 miles from home)
Did not obtain pricing. They indicated they would not charge for pick-up and delivery of tractor for warranty work for the first year.
I am located in Massachusetts and I understand the cost of tractors is higher in the Northeast. Looking to pay a fair price and be comfortable with the dealer. I am somewhat disappointed that Dealer A indicates no break on pick-up and delivery for warranty work within the first year. I also indicated that I do not really see myself using the skid steer quick coupler and asked if I would be able to save some by going without it. I was told they pretty much order all the loaders for this model with the skid steer quick coupler.
As I do not have a trailer and would prefer to hold off on buying one right away, I really want to purchase a tractor that would be considered the least likely to have any maintenance issues. With this in my mind, I question myself and think based on all the reading I have done on this forum its seems like I have heard the least complaints with regard to the B7800 and B3030.
Thanks in advance for your comments and suggestions!
   / Considering L3400 / Quotes #2
I definately think that you should go with the skid steer coupler regardless which dealer you go with. Much much more work to switch to one after you get the tractor without one.
Unlike dealer A, my dealer had no clue that you could even get one. If I was a dealer, I doubt I'd order loaders without one either. I'd consider it doing a dis-service to my customers who didn't know any better :)
If dealer A and dealer B are otherwise equal, I would go with B and get the skid steer QA with a compatible bucket - will cost you about what A was quoting you for the tractor/loader/bucket. I like the idea of the dealer being willing to pick up without charge for warranty work. Plus the BH price is cheaper too.
   / Considering L3400 / Quotes #3
Operate a DT and immediately switch to the HST. You will buy the hydro. Well worth the $1000.00.
Terry
   / Considering L3400 / Quotes #4
I second that post on the hydro. By and large these are very reliable machines. Kubota probably sells more of these than any other in the CUT line up.
   / Considering L3400 / Quotes #5
I just past 75 hours on mine. So far I have used it for digging in the dirt and I love it. It does like a lot of rear ballast. I now have loaded tires and a 1,300 ballast block for when I use the FEL. Your backhoe should be about the same. HST is the only way to go. The FEL could use a little more break out force.
   / Considering L3400 / Quotes #6
You can always rent a trailer for ~$30 a day if you had to.
As for the quote, they seem reasonable for your location. I paid 17.2k for the hst about this time last year.
The l3400 is a solid work-horse of a tractor, too.
   / Considering L3400 / Quotes #7
Terry
You need to test ride each for sure. It's not a foregone conclusion. I have a gear tractor w/ shuttle. I seriously doubt I'll go for a hydro any time soon.
A friend has a JD w/ hydro and it is nice but that constant high pitched wine is annoying as ****. As for reliability, it ain't so. You can't beat a gear tractor for reliability in MOST situations.
In my job I'm around heavy equipment w/ hydro tranny's every day. They break/leak/fail all the time. The good majority of gear machines don't have as many problems.
If all you're going to do is mow they're good tranny's. I don't like them for dirt work. Shuttles (or GST) are the way to go IMHO.
Either way if it's orange, you're good to go! Good luck.
   / Considering L3400 / Quotes #8
Absolutely try both. I was all set on a geared tractor because that is all I have ever known. But after operating the hydro I could see for my application it would be better. Also, my wife sometimes uses the tractor and she has no prior experience. I feel it is safer for her because if she gets in a panic situation she lifts her foot and the tractor stops. I would not feel comfortable with her on a geared tractor. The same for my dad who is getting on in years. I feel a lot better with him using a hydro. Either one will be a great piece of equipment. Choose the one that will best fit your application.
Terry
   / Considering L3400 / Quotes #10
I was in a similar situation to you. I started seriously looking a couple months ago after two years of renting and research and surfing. Went to a dealer with the intention of taking home an L3400DT. After many test drives over the course of two months, I ended up with a L3240HST with the larger loader (724), quick-tach bucket, and a BH90 backhoe. I highly recommend the quick tach bucket for future uses that you may not anticipate now. It's worth the couple extra dollars for.
My tractor was delivered this past Saturday, so I've only had the chance to put on about 6 hours of snow removal so far, using a 7' RB and the FEL. I have moved a lot of snow with an L2900DT, and had good success. However, after using the HST for just a few minutes on Sunday with the new tractor, I have no regrets for the upgrade and will never look back. Kubota HST's have excellent track records and I know this will serve me well. I'll be doing a lot of loader work in the future, with lots of tight manuvering through the woods...so the HST will really come in handy.
I have a similar storage situation as you - my garage door is a 7' door. I have to drop the ROPS to park it, and the backhoe has to go in partially dropped. Right now, the backhoe is off the tractor, so no big deal. I'm sure that over time, I'll get frustrated at dropping the ROPS or the backhoe to park it, but it is what it is. I don't think an L3400 would have fit either, and I didn't want to go any smaller than that based on the needs that I have.
Ultimately, it is a fun choice to make. You'll be happy either way you go! Good luck!
Chris
12in Backhoe Bucket (A52128)
12in Backhoe...
2019 CHEVROLET EXPRESS VAN (A51243)
2019 CHEVROLET...
2025 12V Diesel Pump and Hose (A50324)
2025 12V Diesel...
ASSET DESCRIPTIONS & CONDITION (A52141)
ASSET DESCRIPTIONS...
Killbros 385 Gravity Wagon (NICE) (A50774)
Killbros 385...
(10) 2 PLUG VALVES (A52472)
(10) 2 PLUG VALVES...
