Connect PTO to 3/4" shaft?
   / Connect PTO to 3/4" shaft? #1
Westonium
Chehalem Mountain area, OR
JD 4310
I am trying to convert a old gas powered tiller to be PTO driven, but I am stuck trying to source a male 6 spline adapter to sleeve over the 3/4" keyed shaft.
Any ideas?
   / Connect PTO to 3/4" shaft? #2
I would think check out sprayer parts,
Surplus Center in Lincoln Nebraska has adaptors as well,
I would guess this is what your looking for,
(sorry I miss read and posted a link for a female unit)
this is the best I can come up with,
Surplus Center Item Detail
and then one would have to have a sleeve made or bushing to fit the 3/4 to 1 1/2" opening,
or one could possible use this
and make an adaptor to bolt on for the 3/4" side.
this would be a touch clunky but would possibly work,
and
or
or have a machine shop weld a weld a hub bushing to
Surplus Center Item Detail or have a machine shop drill it and weld it to the 3/4 shaft,
   / Connect PTO to 3/4" shaft? #3
Yesterday i needed an M8 tap. When i was at the shop, i was thinking to myself, that this single tap, (cheap quality) would be lost or broken very soon. I ended up buying an M3 upto M12 tapping and cutting set, in a very nice suitcase so i can directly see when something is missing. (and yell at any person who failed to return it after use) :p
Price was 210 euro, but i said it was too expensive for my likings, as i came into the shop to buy just a single tap.. Shop supervisor then said he could give me 10% discount, or a price of 185 Euro. Then i replied " you know, SPENDING money is what people do in the pub. Buying lifetime quality tools, is INVESTING it."
I think he liked what he heard, as he promptly gave me another 5 Euro rebate by saying he'll sell it for 180... :D
Anyways, back on topic: I needed the tap to cut a threaded hole onto the sprockets of the street sweep i'm building, i cut off the shafts, and lost the ends with the keyways. I simply drilled and tapped an M10x30 bolt into each sprocket/shaft, in axial direction. This way it functions just like an official shaft key, only my version is round and threaded, so i dont need a mill and a broach to cut keyways ;)
drawback is that you can only attach a sprocket to a shaft with this method, when the sprocket is on the very end of the shaft.
Mccormick X6.55 (A50123)
Mccormick X6.55...
UNUSED RAYTREE RTSG30-30" STUMP GRINDER (A51248)
UNUSED RAYTREE...
E-Z-Go Freedom TXT Electric Golf Cart (A51694)
E-Z-Go Freedom TXT...
JOHN DEERE 3040 TRACTOR (A50459)
JOHN DEERE 3040...
2005 FORD F450 XL SUPER DUTY DUMP TRUCK (A51406)
2005 FORD F450 XL...
1998 C6500 Chevy, 3126 Cat Engine (A52384)
1998 C6500 Chevy...
