Connect post pounder to Bobcat T300
   / Connect post pounder to Bobcat T300 #1
billmuis
Alberta, Canada
Kubota, John Deere
I have just picked up a used Shaver HD-8 post pounder and would like to hook it up to my T300. The Shaver HD-8 basically has a single acting cylinder with a spring return which is controlled by a 3-way valve. The 3-way valve has a pressure relief set at 1500 PSIG. It has a 3/8" supplly hose and a 3/4" return hose. I guess the large return hose is ment to dump the fluid to the tank quickly with minimal restriction as the springs pull the ram down to pound the post. My T300 has 3 flat faced hydraulic connections which I understand to be high flow at the top (largest connection), case drain in the middle (smallest connection) and standard supply at the bottom (mid size connection). I think that all I need to do is connect the standard supply line to the supply side of the post pounder valve and the return from the valve to the case drain connection but I am wondering about the size of the case drain connection. It seems small relative to the post pounder return line which is 3/4" (the hose looks like 1"). Will I have too much restriction when dumping the fluid out of the cylinder and thereby slow down my pounding stroke? Also, can anyone tell me what the T300 hydraulic attachment pressure is at idle? At higher RPM? Is it adjustable? I'm new to skid steer ownership and any advise or experience would be greatly appreciated. Thanks
   / Connect post pounder to Bobcat T300 #2
The t300 is capable of 21 gpm with pressure of 3300 psi. The shaver 8 hd is designed for 3-4 gpm. Even at idle, the t300 will have way too much flow. The shaver will not work with that flow rate. You will need at least a flow diverter to control the flow.
The psi will be regulated by the shaver pounder. The small dump connector on the t300 is designed mostly for slowing down hydraulic motors so they do not stop too rapidly which can create at lot of back pressure in a skid steer and hard on the hydraulic pumps. Just connect your return hose from the pounder to the standard bobcat connector.
Flow diverter
Surplus Center - SAE 12 HYD FLOW CONTROL VALVE RD112-30
Ford Pickup NR (A50323)
Ford Pickup NR...
John Deere Z970R (A50123)
John Deere Z970R...
(NEW) 2025 DOWN 2 EARTH GOOSENECK TRAILER (A51247)
(NEW) 2025 DOWN 2...
2008 Jeep Wrangler Unlimited X SUV (A53117)
2008 Jeep Wrangler...
KOMATSU PC150-5 EXCAVATOR (A51246)
KOMATSU PC150-5...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2015 Peterbilt 320...
