The hydraulic/hydro stat is all one unit and uses the same fluid correct on the ex3200 correct? I was always under the impression this is the case until i went to look into changing it. My unit has around 500 hours on it, and I'm actually adding 3rd function to it, so i was kicking around changing the hydraulic/ hydro stat fluid.
What is an acceptable hydro stat oil for this tractor? Will the stuff from blains farm and fleet work fine? or do i need to be more picky and buy the expensive stuff from Yanmar/Cub Cadet.
