Confused - Need Help
   / Confused - Need Help #1
dbyrne36
Hello All,
First, I have been browsing the site for a few months and it has been very helpful. However, the deeper I get into looking for a new tractor the more I feel I don't know, so I could use your help.
So here is my situation. I am moving to 10 acres in the next month, and I will probably pick up another adjacent 5 acres next year. The land is primarily wooded, except for the area right around the house and the garden, which is about a 1/4 acre. The property is rocky, but not too bad, and gently slopes down to the lake. Here is what I am looking to do with my new tractor:
- Work the garden
- Move earth (I have A LOT of landscaping to do)
- Move trees (drag logs and move rounds using the bucket)
- Bush hog (but little if any mowing)
- Eventually, with implements, split and chip wood
- And of course anything else I can justify using it for :)
Based on the above, I was thinking that I need a 4x4 tractor with a front loader with at least 20hp. So, in looking at tractors, I narrowed it down to:
- Kubota L2800
- Kubota B3200
- NH TC30
As I was looking at the tractors, though, the prices seemed to get up there pretty fast. Based on that, I am second guessing the direction I was going. So here are my questions I could use your help with:
- Based on what I outlined what size tractor do you think I need?
- What makes/models would you recommend?
- Any other suggestions/input?
I worked my through college on a farm, so I know my way around a tractor, but it has been 20 years since then. So I would appreciate any input. Thanks!
   / Confused - Need Help #2
Check out a Mahindra 2816 tractor, or if you are really looking for economy check out the Mahindra 2525 tractor.
   / Confused - Need Help #3
Hello All,
- Work the garden
- Kubota L2800
- Kubota B3200
- NH TC30
I have 10 acres of flat pasture land. My first tractor was a new 2005 Kubota B7510HST (21 hp engine, 17 hp pto, 4WD, power steering) with the LA302 FEL (4-ft wide bucket, about 800 lb lift capability). It was fine for landscaping around my new place (plowing with a middle buster, 4-ft wide rototiller, 4-ft box blade, etc), installing paver block walkways and a 20x20ft paver block patio, moving material (soil, mulch, sand, gravel, etc), clearing the junk out of my weed patch.
Last year I decided to put a hay crop (oats) on 6 of my 10 acres and traded that B7510 for a new 2008 Mahindra 5525 (54 hp engine, 45 hp pto, 2WD, power steering). I mention this only to remind you that plans change and sometimes require a new tractor purchase relatively quickly. So it helps to think hard and plan ahead before dumping a wad of cash in a tractor purchase.
If I were in your situation, I'd look for a 30-35 hp (pto) tractor with HST, 4WD, power steering and a FEL with a 5-ft wide bucket. All the tractor manufacturers have something to offer with these specs.
If new tractors cause sticker shock, then check out 2-5 year old used tractors (dealers, eBay, craigslist). Most tractors depreciate 15-20% in the first year. By the 5th year, the depreciation is 30-40%. You can find 5-year-old CUTs with 500-800 hours pretty easily and, assuming proper maintenance, a tractor like this is just getting broken in.
   / Confused - Need Help #4
Dbyrne36
If you have a the Kioti dealer near by check out their line up, 20 HP and up, you may find quite a difference in price. Most owners are real pleased with these machines.
Harvey
   / Confused - Need Help #5
I know a few people who rave about their Kubota 3010's - and you can sometimes find them used at a reasonable price.
comparable to what you listed but generally lower priced:
Kioti CK 25, 30, or 35
Mahindra 2816 or 3216
TYM 233 or 273
if you want to step up a frame size, there are a LOT of options under $20k, and often an extra $1000 will get you a larger frame machine (bigger frame, more weight = more traction, stability when FEL bucket is full, etc...)
ps: part of the country you live in can make ofr a big difference in prices - so would be handy to have a clue as to state or region where you will be using the tractor.
Thanks all so far for the help. To answer the last question, I am in the greater Tulsa, OK area. The biggest dealers within a reasonable distance carry Kabota, New Holland, Massey, John Deere, and Mihandra. There is no one nearby that I can find that carries Kiota or Bob Cat tractors.
   / Confused - Need Help #7
Wichita or OKC would probably be your closest Kioti dealers.
Check White Star there in Tulsa for Bobcat Tractors.
   / Confused - Need Help #8
I do everything you do on a pacel of land the same size as you are planning to acquire, except work a graden and bush hog. I also do a lot of snowblowing. I have a Kubota B3030HSDC (30 hp) which is good for what I do. You probably wouldn't have to have the cab.
I couldn't imagine using my tractor for the garden that I have which is quite small (i.e., tractor too big). On the other hand I couldn't imagine doing a lot of wood work (chipping, and hauling dead trees, splitting wood) with a smaller tractor. I would say the same would be true with landscaping, of which I have done a lot more than I anticipated. In some respects I wish I had a larger tractor, not a smaller one.
   / Confused - Need Help #9
If you like the tc 30.. look at the smaller NH models as well.. while 10-15ac is alot of land.. if yours is all wooded.. then smaller is deffinately a plus.. something like a 1630 ( if looking used ).. or the tc 21 or 24.. etc.
soundguy
Hello All,
- Work the garden
- Kubota L2800
- Kubota B3200
- NH TC30
   / Confused - Need Help #10
My memory of OK distances isn't too good, but consider John's Tractor, Vinita, OK.
2013 Bobcat E32 Mini Excavator (A51691)
2013 Bobcat E32...
2000 Freightliner FL70, 5.9 Cummins (A52384)
2000 Freightliner...
2018 KENWORTH T880 (A53843)
2018 KENWORTH T880...
2019 Ram 1500 Classic 4x4 Crew Cab Pickup Truck (A51692)
2019 Ram 1500...
2014 INTERNATIONAL PROSTAR SLEEPER (A53426)
2014 INTERNATIONAL...
2025 CFG Industrial QK16R (A50123)
2025 CFG...
