Confused about Toolcat attachments? Do they all need the 7pin plug? Can I use reg skid steer ones?
   / Confused about Toolcat attachments? Do they all need the 7pin plug? Can I use reg skid steer ones? #1
chriswilliams2000
Kubotas GR2120 BX25
Hi I am looking at a used 5600 and it has some attachments with it. But in terms of say a grading rake, will the 5600 fit reg skid steer quick attachments or is the toolcat unique? These are obviously just manual ones, ideally a grading blade and rake I would like to have out front. Just wanted to make sure they will work and when the 7 pin part gets in the way? Thank you in advance.
   / Confused about Toolcat attachments? Do they all need the 7pin plug? Can I use reg skid steer ones? #2
The Toolcat does have the standard skid steer quick attach on the lift arm. I use a snow plow, finish mower, grapple, and buckets on the SSQA. Every maker has their own connector for inputs to control the attachment and Bobcat uses the 7-pin. Electrical adapters are used on attachments with different connectors. My attachments don't use the 7-pin because they are simple on/off. Something like a snowblower that has valves to control the chute etc would have the 7-pin.
OIL WORKS INC. AIR TONGS (A50854)
OIL WORKS INC. AIR...
2008 Ford F-250 Service Truck (A50323)
2008 Ford F-250...
Hydraulic Cylinders (A49346)
Hydraulic...
2019 Skyjack SJ1256THS 12,000LB 4x4 Rough Terrain Telehandler (A49346)
2019 Skyjack...
2008 Ford F-250 Reading Service Truck (A48081)
2008 Ford F-250...
Vacuworx Vacuum Lifter Pad (A50860)
Vacuworx Vacuum...
