concrete repair
   / concrete repair #1
Mosey
Veteran Member
Conifer, Colorado
2000 New Holland TC29D with 7308 FEL, and top & tilt. 1950 John Deere B. 1940 Farmall A.
While removing snow, I have broken pieces of concrete off, usually 1 to 3 inches across and about 1 inch deep. It's at the edge of where the crack for expansion goes across. The edge of the blade drops down and then gets a hold of it and knocks a piece out. How do I repair these areas?
   / concrete repair #2
Epoxy products specifically designed for concrete repair are available at most hardware outlets and should do a good job, You might be best to wait until spring as the repairs might take better in warmer weather. Follow the instructions and you shouldn't go far wrong.
Maybe a stainless steel or aluminium strip fixed across the movement joint might prevent this happening in future.
1996 Allegheny 35ft 25 Ton Flatbed Equipment Trailer (A51692)
1996 Allegheny...
23311 (A51694)
23311 (A51694)
17101 (A53421)
17101 (A53421)
1979 MACK R MODEL WINCH TRUCK (A53843)
1979 MACK R MODEL...
CASE 580 (A47477)
CASE 580 (A47477)
Sakai SW880-1 (A47477)
