concrete recipes and preventing cracks.
   / concrete recipes and preventing cracks. #1
jt7157
north central tennessee
new holland tc55da
I'm getting ready to pour a concrete porch. It will be eight feet wide and five inches inches thick at the house and four inches thick at its end. My main concern is cracking. I will use steel re bar in a grid on two foot centers. I plan to use the concrete with the fiber mixed in the recipe. Are there any other additives that will help with cracks? I guess my question is this: what is the best recipe to help prevent cracking, especially those annoying hairline cracks? Thanks in advance.
   / concrete recipes and preventing cracks. #2
I don't know the size of your pad other than the 8' dimension. If I did, I could suggest saw joints in the top to make control joints for cracks.
Are you doweling the pad to the house foundation? This can keep the slab from sinking into the "overdig" around your house foundation. (How many times do you see a slab sunken near the house or a sidewalk poured near a foundation that tilts towards the wall instead of away from it?) I usually compact the soil from the foundation out about 3 feet since this soil is usually soft for up to 30 years after the house is built. I take a small sledge hammer and punch holes into the block of the house and allow my rebar rods to stick into the cells in the hollow block. Then right at the start of the pour, I get shovel-fulls of wet concrete and pack it into the open cells of the block to secure the rebar and close up the holes I created. If you have a poured concrete foundation, drill the holes into the wall w/ a hammer drill , then epoxy the rebar into the holes you drilled.
Try to keep your rebar in the lower 2" of the slab, not the upper 2"
Make sure you have good drainage under your 4" thick stone bed. Drainage should roll away from the slab to let water out from under the stone. It helps to tamp the stone to get rid of any soft spots, too. That way if you have a freeze, it won't heave the pad.
Try to mist (not too much, no puddles) the concrete frequently during the curing process to keep the surface from spalling/shaling.
That's about all you can do. the only gaurantee you can give a customer about exterior concrete is that it might crack someday. It's at the mercy of the earth underneath, the water from the heavens and freezing in the winter.
Good luck.
   / concrete recipes and preventing cracks. #3
Mixed correctly w/ water, concrete is guaranteed to do 2 things.
1; Get really really hard.
2; Crack.
You can 'only' control one of those.
Either install crack joints as you go or cut them in afterwards.
   / concrete recipes and preventing cracks. #5
Have you considered what strength concrete you will choose and will it have air entrainment?
   / concrete recipes and preventing cracks. #6
Use fibermesh & cut it the next day.
   / concrete recipes and preventing cracks. #7
Make sure the ground is prepared where you plan on pouring the concrete. If it's not settled it can sink over time and cause cracks. My shop floor is close to 15 years old now and still has no cracks. If you prepare the base properly and use good concrete (ask the concrete company about different mix's, they are the experts). Expanssion joints will also help a lot with the prevention of cracks later.
   / concrete recipes and preventing cracks. #8
Make sure you have a good base first of all. Tamp down some crusher run rubble. On exterior work I always use 4000psi concrete with fibermesh added. Rub out a good finish as it cures and then brush top with a broom. Score concrete 1/4" or so where you think craks should go.
   / concrete recipes and preventing cracks. #9
I've never seen a porch floor with a broom finish.
That's usually done on sidewalks.
Porch floors are finish troweled smooth as glass. The only time I leave concrete rough is when I'm applying brick or flagstone later.
   / concrete recipes and preventing cracks. #10
yeah, sorry your right builder. Nix the broom finish!!!
2012 Big Tex T/A 20 ft. Gooseneck Trailer (A53117)
2012 Big Tex T/A...
2019 INTERNATIONAL 4400 SBA 4X2 SERVICE TRUCK (A51406)
2019 INTERNATIONAL...
2012 CHEVROLET 2500 HD SERVICE TRUCK (A51406)
2012 CHEVROLET...
Shindawa EC7600 Concrete Saw  (A52384)
Shindawa EC7600...
FELLOWS PAPER SHREDDER (A53843)
FELLOWS PAPER...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
