Concrete Question
   / Concrete Question #1
luscsmith
I am having a concrete drive poured and would like to know if I can substitute rebar and/or wire with thicker higher psi concrete with fiber.
Thanks, Scott
   / Concrete Question #2
Thanks, Scott
Don,t know where you live but will tell you here in N.MN. the fiber mesh doesn,t hold up as well as the wire mesh.And I was told by the cement guy,s that sun light isn,t good for the fiber.I,v had both poured and will stick with wire or rebar.Dave
   / Concrete Question #3
Agree with Dave, no matter where you are, for a drive
   / Concrete Question #4
Scott, supposedly rebar or wire are placed in tension areas of the concrete pour as cement is considered to have zero strength in tension.:)
On your question I'm so many years out of date I'll not hazard a guess.:eek:
   / Concrete Question #5
Thanks, Scott
Scott,
I talked to a friend of mine that does concrete work for a living. His reply was that the fibre works fairly well inside of building but does not last as well when exposed to the elements.
I have not seen them but he said there is a company or companies that are experimenting with plastic or fibre rebar. The reason being it would be imune to raod salt and in theory would last longer.
For today I would use rebar and or heavy mesh wire with good concrete mix. aound here the difference in price from 5 bag to 6 bag mix is $6 / yard.
Roy
   / Concrete Question #6
Utilizing a higher strength concrete will improve the compressive strength of the concrete but will not appreciably change the tensile strength. A 2*0=0 sort of thing. The steel reinforcing takes the tension up in the concrete to prevent differintial settling and to deal with some internal stesses. I tried fiber instead of rebar for a sidewalk one time and it improved the strenght of the concrete but did not prevent the individual sections from settling at different rates causing the edge of one section to be slightly higher than the edge of the adjoining section. To sum up I would recommend utilizing the rebar/welded wire.
   / Concrete Question #7
Unless the steel is pre-stressed (Pulled and held in tension while the cement hardens), the only thing the steel does is keep the broken concrete sections reasonably together. I've used the higher strength cement mixes without steel at the same thickness and been surprized at how crack free its been. But, these were small sections which replaced old broken ones, and the setlement of the underlayment probably had a lot to do with it, too.
   / Concrete Question #8
Ummmm.....No.
If that was the case parking ramps would fall down under their own weight.
   / Concrete Question
I am planning to pour 5" of 4,000 psi, will that be good for a drive?
Scott
   / Concrete Question #10
Scott
That is what I used on my driveway last fall. 14' wide, wire mesh and used 2 rows of rebar near the outside edges. 14' is probably wider than needed but nice for larger trailers.
UNUSED FUTURE CW59 - 59" PADFOOT COMPACTION WHEEL (A54757)
UNUSED FUTURE CW59...
2013 CATERPILLAR 320EL EXCAVATOR (A51246)
2013 CATERPILLAR...
2025 Auger Mini Skid Steer Attachment (A53421)
2025 Auger Mini...
2013 CAT 950K WHEEL LOADER (A52472)
2013 CAT 950K...
2011 Mack GU713 Granite Cooper TM-1882 18 Ton Crane Truck (A55788)
2011 Mack GU713...
2010 Dewalt Air Compressor (A55787)
2010 Dewalt Air...
