Concrete question
   / Concrete question #1
woodlandfarms
Super Member
Los Angeles / SW Washington
PowerTrac 1850, Kubota RTV x900
I am repairing a couple of fenceposts at my house in LA. I dug the hole, put in the redwood (it is all we have here) and dumped in some concrete. I thought I had grabbed the Post Hole concrete mix, but when I was cleaning up I realized I grabbed mortar mix by mistake. I don't think this is an issue, just a reduced agragate but I had to ask
   / Concrete question #2
I guess it depends on what you're trying to keep on one side of the fence; no?
By that I simply am saying that I wouldn't go digging it up or even worrying about it unless the mortar proves (by crumbling) that you should do it over again.
Probably, truth be told, you've done nothing worse than spending more than what was required for the job, owing to the fact that an aggregate mix is usually cheaper (price/volume) than mortar, and that mortar is the "glue" in some structures far more important than a fencepost.:cool:
   / Concrete question #3
Here's my saying for something like that...
"Three words...Itl be fine...IBF". (It will be fine...but it's better said as 3 words, it works better).;)
   / Concrete question #4
guys that set posts for a living will tell you the only reason they use concrete is for the gravel...
Just gravel (no sand & portland) will set a post just fine
   / Concrete question #5
I only imagine much has to do with soil condition. Around here for field fence or barbed wire, I use dry sand. We have a few out-buildings with dirt floors that havent seen light or water in 30+ years, it is a real fine sand. I just shake the post while filling the hole, by the time it gets full it feels like it was set in concrete. I only do this for the corner/brace posts.
   / Concrete question #6
You'll be fine. Whether you used mortor or post hole concrete mix makes no difference, the post will rot off at the same place in the same amount of time. You can slow it down some after the mortor dries by running a bead of calk where the mortor and post meet.
   / Concrete question #7
We just put up a 15'x25' woodshed for an old fella up the road. He had us use 16' 6x6 PT posts set in crushed limestone. Then he dumped old motor oil on top of the stone. The next day the stone had settled 3-4inches and there was NO movement in those posts. Claims that he used to do this on all his pole barns. Every few years he would add a bit more oil. Frost never moved anything either
   / Concrete question #8
Wife was setting some tiles and mixed up a full bag of thin set......first time she'd ever mixed anything up. Of course,it got hard. Ended up burying the thing to get rid of it. I thought a couple of whacks with the hammer would do it.....HAH!!
   / Concrete question #9
Then you drop a well line in right next to the oil contamination, right? It doesn't take much oil to contaminate an aquifer, but it might take a hundred years or so. Nothing like taking care of the grandkids.
   / Concrete question #10
[Just gravel (no sand & portland) will set a post just fine/QUOTE]
That's probably true in some places and with the right kind of gravel, but I heard that about gravel and made the mistake of trying it with a pickup load of pea gravel. It looked good when I was doing it, but then in the hot, dry part of the summer that "Wilson Clay Loam" soil dries and cracks and the gravel disappeared into the bowels of the earth and I had loose, leaning fence posts sitting in big holes
2015 SkyJack SJ86T 4x4 86ft Telescopic Boom Lift (A52377)
2015 SkyJack SJ86T...
2013 Big Tex 16GP-20 Gooseneck Trailer (A53117)
2013 Big Tex...
2012 GREAT DANE 53FT REEFER TRAILER (A53426)
2012 GREAT DANE...
2013 Toro Workman HDX Scissor Lift Utility Cart (A51691)
2013 Toro Workman...
12 in Small Excavator Bucket (A52377)
12 in Small...
2022 Kubota B2601 (A50123)
2022 Kubota B2601...
