Concrete Patio Built On Dirt???
   / Concrete Patio Built On Dirt??? #1
MikeFromVA
Where VA, WV, and MD meet
John Deere 4110
I am having a stamped concrete patio installed and the workers showed up today. When the salesman was here, he told us how they would excavate down about 4" and put in gravel before pouring the concrete onto the gravel base. The workers showed up today and started building the forms ontop of the grass/dirt without excavating. Their foreman told me that's the way they do it now saying that in the hard clay of Virginia, the water collects in the gravel (above the frost line) and heaves the patio when it freezes. He assured me that since they are using 4" thick 4000 PSI concrete, it would be fine. They have given me a 3 year guarantee in writing. Should I be worried?
   / Concrete Patio Built On Dirt??? #3
There shouldn't be grass under the concrete; should at least be bare dirt.
I have seen them on top of clay here, but we don't freeze. Check with another contracor, and or the salesman too. Also, check code in your area.
These folks Viginia Landscape contractors could direct you. Patio's are an integral part of landscapes, and should be specced out for specific build requirements. California has the same association. Concrete, forms, and base compaction ect are spelled out in thier literature. I have the Calif book at home, and can look this up if you'd like.
Also, they quoted you for excavation, base rock ect. If they are not going to do this, your job should also be less expensive.....
   / Concrete Patio Built On Dirt??? #4
   / Concrete Patio Built On Dirt??? #5
</font><font color="blue" class="small">( When the salesman was here, he told us how they would excavate down about 4" and put in gravel before pouring the concrete onto the gravel base. )</font>
Thats what you were sold, send the foreskin and his losers home.
   / Concrete Patio Built On Dirt??? #6
   / Concrete Patio Built On Dirt??? #7
You should be worried and stop the nonsense now, IMO.
It might last three years, and then the cracks show up. I'd want more than three years out of a patio, if mine.
   / Concrete Patio Built On Dirt??? #8
I just talked to the owner of the company. He said they will put down gravel if I want them to. They are one of the largest stamped concrete patio installers in the area and he says that almost all of their installations have no gravel. They do install rebar and he stands behind his work. Basically, I've decided that he is the professional and I should trust his opinion. If I ask for it, they will install the gravel - it's the same price either way. He says that he stands behind his work and I guess I will trust him.
2012 Trail-Eze TE801 48ft 50 Ton Slide-Axle T/A Tilt Trailer (A51691)
2012 Trail-Eze...
2014 Broce KR350 (A50123)
2014 Broce KR350...
20" Sea Container (A47384)
20" Sea Container...
2018 FORD F-150 XL CREW CAB TRUCK (A51406)
2018 FORD F-150 XL...
2025 CFG Industrial MX12R (A50123)
2025 CFG...
