Concrete floor in a barn "how to" advise
   / Concrete floor in a barn "how to" advise #1
ric
Marengo, Ohio: email videos@bright.net
Kubota 245DT and 175F
I have an old horse barn 25 by 35 in fair condition. It needs a new roof, several outside panels replaced and frame boards replaced all of which seems staright forward. The big issue is this barn has a dirt floor and I'd like to put in a concrete floor. What is the best way to put a concrete floor in this building? Thanks, ric
   / Concrete floor in a barn "how to" advise #2
Ric,
Last fall I had a similar project in which my old barn had a wooden floor in it. Seems two owners before used the 36x24 barn for a wood shop. When I moved there the floor was totally rotted, seems the brainchild that built it put the floor joist, rough cut 2X8's, directly on the ground. Well you know what happens to wood when it lays on the ground for years? It rots and draws termites. I had sections of joist that were 2x8's at the outside walls and then went to nothing towards the center of the barn. I appears that you don't have such a problem so heres how I fixed mine.
My barn was sitting on 6" cedar post every six feet or so, they too were rotted and infested with termites. I ripped out all the rotten flooring, plywood, and the joist leaving the dirt floor. With the flooring removed I noticed that the post raised the barn about 8" off the ground. I knew that I also wanted to concrete the floor eventually and that the post needed replacing.
I opted to dig a trench along the perimeter of the barn while it was supported by the posts in order to pour a concrete footer. I had decided that I would not use posts again and set the barn back on a concrete block foundation. So with my trench dug I jacked the barn up slightly and blocked it with short RR ties that I had laying around, I cut the post off about half way up and began pulling the post out with a Hi-Lift jack and chain. I repeated the process of jacking, blocking and pulling post until I had all the post out and the barn was sitting on RR ties.
Next I finished cleaning out my trench and then poured a footer. I did this with a gas powered Concrete mixer, 72 bags of quickrete and a whelbarrow, remember I am tractor impaired. What a pain, but I was afraid that a concrete truck would show up and rush the job and I needed to do somethings as we went along. If I was doing it again I would defintiely get a truckload of concrete.
After the concrete cured and I removed any forms that I had I began laying one course of Concrete Block around the perimeter, leaving spaces around my RR ties to jack it up and remove them. Once he blocks set up I set the barn back down on the Concrete Blocks and anchored it down.
I ordered 20 cubic yards of #57 gravel and placed it inside the barn for a floor. My buddy with a Bobcat came over and helped with this thank goodness. My wheelbarrow was already stressed from the concrete.
Anyway this is getting very long winded just to tell you that it still sits in that condition, I am saving up for a load of concrete someday and in the meantime my gravel is getting packed down to provide a nice base. I figure I will pour a 4" wire mesh reinforced slab and that will bring me up just to the top of my Block I laid and should last forever.
I will try and post a picture.
Matt
Matt,
After reading your post I am left to wonder how you entered your post from your hospital bed... Look forward to seeing your picture if you get it posted. All the exterior wall and interior support posts in my barn are sunk in the ground in concrete. My dilema is do I dig the floor down several inches all the way around fill with several inches of gravel then pour concrete over the gravel and rebar or ? Let me know what you think.
Thanks, ric
   / Concrete floor in a barn "how to" advise #4
Ric,
I can't find my pictures. I will keep looking.
I would think that digging it out about 6-8 inches would be best. Ideally you would like to have about 4" of gravel and at least a 4" slab of concrete.
Keep me posted on what you decide.
Matt
   / Concrete floor in a barn "how to" advise #5
Re: Concrete floor in a barn \"how to\" advise
Ric,
Depending on your soil I would dig it out 6". Then I would fill back and screed 2" of sand or man sand. You can pour over the dirt if it's packed good enough but the sand will make it much nicer to get level. Then from there just form up the sides by the posts and set your screeding runners and that should be all that you need.
   / Concrete floor in a barn "how to" advise #6
Ric,
I will offer another approach, not to say there is anything wrong with the other ideas offered. Most of the old barns I have been in have a pretty solid dirt floor that I would pour right over. It doesn’t sound like you have the structural issues that Matt had so exterior footings are not required. Your interior posts are already set in concrete and it doesn’t sound like they have structural problems. If it would not create problems at your entries, set some pressure treated form boards along exterior walls and pour a 4” slab with steel reinforcement. Seems like digging 6 to 8” down would be a tough job. Think of it like building a parking pad under a roof.
MarkV
   / Concrete floor in a barn "how to" advise #7
If I were doing it, I would also include a layer of visqueen plastic with 2" of sand over the top. This will prevent moisture from coming up through the concrete and making it damp. Finishing the concrete will be more of a chore, as the water doesn't 'go away' as fast, but you will likely enjoy a much dryer floor. Add this to the other good suggestions you have received.
2012 FORD F-450 XL SUPER DUTY BUCKET TRUCK (A51406)
2012 FORD F-450 XL...
Oil Well Pump Jack with Motor (A52377)
Oil Well Pump Jack...
200387 (A51247)
200387 (A51247)
2020 Isuzu NPR Heil Rear Loader Garbage Truck (A52377)
2020 Isuzu NPR...
JOHN DEERE 1705/6700 (A53084)
JOHN DEERE...
