Roady
Bronze Member
I need some help on this one guys. I've been really debating this in my head for days now and I know, given enough time, I can talk myself into anything.
Around this time of year, I get into my "projects" state of mind. I've decided that this year's theme is going to be concrete. I have a gravel driveway and it annoys me to no end. Plowing and snow blowing are a disaster, not to mention the general look of it. I also need to build a patio on the rear of the house. I've always been a big fan of stone / cement because of the low maintenance and longevity. Pressure treated lumber just isn't what it use to be anymore.
I'm going to start with the patio because that's going to be the easiest. I've decided to go with this because it looks nice and I enjoy DIY projects. Basically it's just a mold that creates a paver look to the concrete. I can color the concrete to my likening and I get to work at my own pace and budget. A couple pics of someone else's work can be found here and here.
A couple of things I want to mention before I get onto my question. The first is that the mold creates individual stones, this isn't a stamp. Once the mold is removed, they are completely separated pieces. They are held together by some sort of mortar mix. The mortar is swept in dry, then sprayed with water to create a bond between all the blocks / stones. The second thing is that the finished cement is 2 inches thick. Now onto my big dilemma.
Can this work for automobile traffic? When I first posed that question to myself I thought NO WAY. Minimum specs for a concrete driveway from any contractor is 4 inches with most saying 5" is the way to go. But then I got to thinking......
The reason for the 4-5 inch thickness is because of cracking. Would it not be reasonable to think that the strength lies with the individual pieces being so small? Sure, I may see some cracking in the mortar joints, but that would be easily patched. What if I used a 5000 psi strength mix instead of the 4000? I know my base is going to have to be perfect. My ground here is hard, very hard. I laid pavers blocks around the house 4 years ago and not one of them have moved. My plan was excavate 4 inches down, plate compact, then lay down 2 inches of cracker dust and plate compact again. I also plan to mortar the blocks with the strongest thing I can find.
Any comments or thoughts would be greatly appreciated.
Roady
Roady
