concrete deer repair
   / concrete deer repair #1
Mosey
Veteran Member
Conifer, Colorado
2000 New Holland TC29D with 7308 FEL, and top & tilt. 1950 John Deere B. 1940 Farmall A.
I just got a concrete deer for free. It was free because the head broke off. I can set it back on and it will stay as long as the wind doesn’t blow and no one touches it. Is there any kind of glue that will work on concrete? My wife had a fit when I suggested duct tape!
   / concrete deer repair #2
My wife has a concrete duck (about 24" high). It got knocked over (by guess who /w3tcompact/icons/sad.gif) and the head broke off at the neck so I had to fix it.
I ended up drilling a hole up into the head/neck and down into the head/body and setting it back together with a piece of re-bar epoxied into the hole and epoxy at the break.
I drilled the hole over-size to make sure the pieces would align.
Worked fine.
   / concrete deer repair #3
Hey Danny, just tell the wife that the duct tape is a radio locater collar. The department of conservation is trying to learn the breeding habits of this particular species of deer. They seem to be quite prolific as they have been spotted all over the country! They are worried they might become a pest animal! /w3tcompact/icons/grin.gif Remember were all in this together and were pulling for you! If the women don't find you handsome they should at least find you handy!/w3tcompact/icons/wink.gif
   / concrete deer repair #4
I have a couple of concrete calves - one has a ear problem - checked the local statuary vendor and he recommended the hole, a pin of some type and epoxy solution already mentioned, but added that you need to seal up the seam or moisture will get between the pieces and if it should drop down below freezing the part will seperate again, he recommended some sloppy concrete and then repaint to seal the seam. I have a lot of fun with my calves by moving them around the yard with the tractor. When I first got them one of the neighbor's kids tryed sneaking up on them. Didn't realize they weren't real until she was about 20 feet away. Right now they are painted as Holstens, son was a dairy science major, think about changing my direction to beef now that he has changed to Chemistry.
   / concrete deer repair #5
Mosey, There are special purpose adhesives made for concrete. They may be found at places like the big orange box (AKA Home Depot) or Lowe's. I think the pin and epoxy route has great merit too. If you fill the fracture line to overflowing and remove the excess, there won't be an opening or exposed porus entry point for moisture. If there is some chipping near the fracture line, after the epoxy or other glue cures well, you can use automotive body filler (Bondo) to fill in the missing places. After the Bondo starts to set up but before it gets really hard you can sand it, carve it with a knife, shape it with a SureForm (cheese grater rasp kinda thingy), or whatever.
How are you going to keep the drunks and other miscreants from shooting it during or near deer season? Seriously I would be concerned with where I placed something that someone with sufficiently impaired judgement to think it real would shoot at it and miss by a bit or MORE and hit the house or someother place that you don't want to take incoming rounds.
Patrick
   / concrete deer repair #6
Mosey
I glued a concrete birdbath stand back together after it broke clean in half.
I didn't use a dowel or anything and this was years ago. Still so strong I can carry it by the top half and not looking like breaking !!
Now for the catch. I can't remeber what I used. Was either Selleys Liquid Nails (A constructon adhesive) or a concrete glue bought in a small tube like toothpaste.
Even have a sneaking suspicion the glue was the same smell etc. as liquid nails.
Check out the hardware store.
Cheers
   / concrete deer repair #7
Why would you want a headless concrete deer? Just stop and think about bringing a headless concrete deer home. Kinda makes you grin doesn't it. I'll be right in sweet heart just give me a minute to get my headless concrete deer out of the truck.
2017 John Deere 652R 52in Stand-On Mower (A42744)
2017 John Deere...
John Deere 310G (A42021)
John Deere 310G...
2011 PETERBILT 365 (A45046)
2011 PETERBILT 365...
2006 GMC C8500 Altec AM547 Material Handling Insulated Bucket Truck (A44571)
2006 GMC C8500...
2007 Toyota Highlander Hybrid SUV (A44572)
2007 Toyota...
70in Heavy Duty Dozer Blade (A44391)
70in Heavy Duty...
