concrete Block building
   / concrete Block building #1
Scotty Dive
Platinum Member
Ct
Yanmar 2020D
Need some guidance here...I have used concrete before but really only for mail box posts, flag poles and mortar jobs.
I want to build a rectangular concrete block with hooks that will attach to the back edge of the box blade and on my back blade - I think 200+ pounds would be good to add some additional counter weight - I have loaded turf tires and a FEL.
So...My guess is to build a plywood box and pour/make some concrete - ...
1. How do I get the plywood to pop off after the concrete has cured?
2. If I place hooks into the cement - do I need to attach it to multiple pieces of rebar for strength? Will the hooks hold or eventually break out due to bouncing and general movement when using the BB or back blade?
Is my idea crazy? - shoot holes in it. I just figured it was a cheap and easy solution to my problem....a lot cheaper then finding suit case weights that would hang on to the BB or the back blade.
   / concrete Block building #2
Sounds like a good idea I would use the rebar as my hooks and bend them so the pass through the whole block and can hook on the back blade. Dont worry about the plywood I would just get a pry bar and pull off. Post some pics when your done
   / concrete Block building #3
Just moisten the forms with used oil. They will separate much easier.
   / concrete Block building #4
We used good ole Johnsons Paste floor wax on plywood forms in heavy constructions jobs. Just rub on a good coating and dont miss any spots and the forms will come off with no concrete adherance. Some oils are not good for concrete strength and ****** the set up so be careful with that. There is a special concrete form oil but cheapest thing is the floor wax.
   / concrete Block building #5
Also just bend an L shape on your rebar and insert it minimum of 6" into the concrete and it should hold. Best to cold bend it if you can. If you get it too hot, you will substantially weaken it. I think that if you have a welding machine, you could fab up some attachment plates to bolt the whole thing onto your box blade. Bolts could also be used as concrete anchors. You could weld on nuts to your attachment plate on the concrete side and then screw in the bolts after you got it all formed up and ready to pour.
   / concrete Block building #6
If you can, I would form the two hooks out of ONE peice of rebar. And make sure it is embedded a good 6" or so into the concrete. It will never pull out.
I would also wad up some wire or old fence and place in there as well. It makes it a lot stronger and you wont have to worry about it breaking into two peices or anything.
This is also a good time to get rid of any old/bent nails you may have. If you are like me, I have a jar full of em. Anytime I tear something down, or re-make something, I save the bent nails. Because I dont like burning them, and I certainly dont like taking them to the scrap yard, because the risk of flat tires there is already high. Anytime I do anything with concrete, I dispose of all my bent nails:thumbsup:
And x2 on not worring about the forms. They will come right off .
   / concrete Block building #7
I just did this for my disk and used regular spray pam on the forms. Popped right off this am.
Once you pour in the concrete make sure and hit the sides of the form with a hammer multiple times all around as it helps smooth the sides. I also put some molding in the corners of the form so the edges are rounded.
I used chains as the attachemnt point because they are versital on moving the blocks and mounting them on different items.
Any pictures?
   / concrete Block building #9
Once you pour in the concrete make sure and hit the sides of the form with a hammer multiple times all around as it helps smooth the sides./QUOTE]
Maybe, but not too many times or the aggregate all ends up on the bottom and the sides in contact with the form get too high a water ratio.:)
   / concrete Block building #10
I just hang 4 50 pound suitcase weights on my box blade.. They were on the front of my tractor before I got a FEL.
2015 Ford Escape 4x4 SUV (A50324)
2015 Ford Escape...
1984 NAVISTAR 1954 CABLE HOIST (A51222)
1984 NAVISTAR 1954...
2017 Ram 5500 Valve Placer Bucket Truck with Versalift STP36NE - 41FT Working Height, Low Miles (A52128)
2017 Ram 5500...
2018 JOHN DEERE 333G SKID STEER (A51242)
2018 JOHN DEERE...
2010 KENWORTH T270 SERVICE TRUCK (A51243)
2010 KENWORTH T270...
2019 POLARIS RANGER XP PROSTAR 900 HD DOHC UTV (A51406)
2019 POLARIS...
