Concrete, asphalt or pavers
   / Concrete, asphalt or pavers #1
Creamer
Elite Member
NE Indiana
1710 Ford, Versatile 150
It is getting time to replace my asphalt driveway as it is old and the driveway needs to be regraded for better drainage. I am debating what material to replace it with.
Asphalt is the lowest cost initially but needs regular sealing to last. Plus it looks kind of passe but i do like the fact that it is black and snow and ice melt off it which is very handy in my climate.
Concrete is the next option in order of cost but it really is not much more than asphalt - maybe 10-15%. Natural concrete does not attract the sun as well but it could be stained darker. It could also be stamped to improve appearance. My concerns are my snow removal is with a tractor and blade and would it chip or scratch and look ugly. If if does is it repairable?
I was also thinking possibly large concrete pavers which provide a different look and if one gets damaged it is replaceable. This would be the most expensive option I believe.
With any of these options I will be ensuring plenty of slope for good drainage as well as tile underneath. Frost heave will mess with any of these surfaces.
I am looking for comments, lessons learned, other options, etc.
Thanks in advance for your help!
   / Concrete, asphalt or pavers #2
The way I see it is that concrete is the only one of the three that is somewhat structural. I.e. supports weight and holds ground better than the rest.
Asphalt can buckle and you can get potholes, not to mention the fact that it smells on hot summer days.
Pavers is a good option but with any equipment on it, you will need to leave a good 1/2 inch of snow to prevent the blade from scraping and picking up the stones. Another downfall is that pavers have gaps through which grass/weeds can grow, and water infiltrates the areas therefore potentially washing out the base.
I have a concrete driveway that needs to be redone soon but it was mixed by hand and the concrete quality is poor, nonetheless it has lasted 17years and had many truckloads pass over it.
The best thing you could do is rent a compactor, dig in say 3 feet (all depends on the soil type in which you live in, my land is swampy/soft so I dug in 3 ft) and backfill with uniform material, gravel and compact everything as you go. Then you could layer 2inch rigid foam if you have wet soil, this will raise the frost line and potentially prevent heaving.
Then add good rebar, say half an inch thick, every foot, assuming you pour 6inches of concrete.
Lastly, when ordering your concrete, get air mixed Into it, essentially microbubbles in the concrete that give space for water to expand inside and therefore reduce cracking.
I would go for a "brushed look" which is simply having a brush pulled along the surface to create tiny ridges, this gives tires/ shoes more traction especially when the concrete is wet/iced over/snowed over.
Hope this helps.
   / Concrete, asphalt or pavers #3
I like the idea of pavers(and its not my $$$) but I have experience with small (8" x 8") pavers on my walkway. One or two can tend to frost heave and at times I will catch my foot on one that's lifted slightly. They are well bedded in gravel then sand but still a couple can tend to heave slightly - I tend to shuffle at times too.
Translate this to your driveway and the only problem I can see is catching either your front blade or rear blade as you plow snow - if there were any frost heaving. I like the patterns you would be able to create with pavers, its easy to repair any that might become damaged and generally speaking they should last a lifetime.
   / Concrete, asphalt or pavers #4
Size and location of the replacement? Front of garage or a mile long road?
   / Concrete, asphalt or pavers #5
Pavers will be the only option that ADDs to the value of your home on resale.
But , why would you want to sell"
to get away from the bumps and snags of running the plow and blower over those dam pavers? ;-)
   / Concrete, asphalt or pavers #6
Since this is under RURAL LIVING...I'll recommend tamped extremely fine gravel...mine has lasted for over a hundred years...:)...(with the dump trailer load of added gravel every so many years)...:)
   / Concrete, asphalt or pavers #7
I have brick pavers there are a Pain in my arse,hate them.To much up keep.If your snow plowing the pavers shift over time and you can easily hook one with your snow plow.I wish I had went with cement.
   / Concrete, asphalt or pavers #8
If frost heaving is present the area should be excavated and back filled with material that does not support upward percolation of water.
   / Concrete, asphalt or pavers #9
I'm a huge fan of asphalt. Love how smooth it is. That would be my first choice, but it has to be thick enough to last and have a solid base. Too many cheapy jobs are done with it too thin, or with a cheap mix. One of my clients works at the asphalt plant, the only plant in the area, and she says that the contractor specs out what mix they want. For city and highway jobs, it's always the best, most expensive mix. For other jobs, it depends on the job and how crooked they are. You really need to know what to specify if you want a good quality mix. I have no idea what that is, but would find out before buying.
Concrete is great, but around here, super expensive and time consuming since you have to do it in sections.
I just have gravel and probably always will.
I love pavers for walkways. Hope to do them in my backyard one of these days. I would never even consider them for a driveway. Too much to go wrong and repair.
   / Concrete, asphalt or pavers #10
Our first time with asphalt lasted 15 years. We just added a layer it will probably last more than 20 years. We have about 700 feet of driveway and it was almost 20k the second time
3/8 '' Wolverine Universal Quick Attach Cut Out Mount Plate (A51573)
3/8 '' Wolverine...
2016 Arising 8.520VTRW 22ft T/A Enclosed Cargo Trailer (A51694)
2016 Arising...
2015 MACK ELITE LEU633 GARBAGE TRUCK (A51406)
2015 MACK ELITE...
20ft Bumper Pull Equipment Trailer (A51572)
20ft Bumper Pull...
2025 20ft. G70 Cargo Transport Chain (A51692)
2025 20ft. G70...
