Computer Start Up Question....
   / Computer Start Up Question.... #1
Junkman
Super Member
North East CT
2003 Kubota BX-22
Don't know if this is the right place to post this, but if it isn't, please move to where it belongs.
When my computer starts up, there are a bunch of programs that I never use that are loaded. I have looked, but cannot find where I can pick and choose what programs I want to start when the computer starts. I am running Windows XP Professional on a Dell Dimension 4100 computer. Any and all help appreciated..... thanks.... the original Junk...
   / Computer Start Up Question.... #2
Here's a technique I have used for a long time.
open Explorer and go to
C:\Documents and Settings\All Users\Start Menu\Programs\Startup
Each shortcut listed there starts a program.
I like to make a sub-folder called 'removed from startup' within that folder. I move un-needed shortcuts into it, so they are easy to find if I wish to resume using them.
In addition to 'All Users' you may have to go to your personal startup folder as well.
Start/Set Program Access and Defaults/Add-Remove Windows Components is another place to tinker with. Make note of what you change here since it isn't obvious what it looked like before you changed it.
Start/Control Panel gets to the heart of your pc but I suggest research on Google anything you wish to change in its subcategories.
And finally here is as far as I have ventured into the 'expert' realm. From a post I made in an XP thread back in September:
After installing SP2 I shut down some Windows background processes that I don't need based on the 'Safe' recommendations at:
http://www.blackviper.com/WinXP/servicecfg.htm
(Find 'Black or White' in his left margin and choose White for a more readable page.)
Again, research via Google if his descriptions aren't suffficient. He emphasizes that XP defaults to running several network tasks continuously, probably so it can integrate into any network the moment you attach it. You don't need most of that after your system is set up, and the running tasks are at risk of being exploited by hackers.
Finally, adding a 512mb ram stick lets everything run simultaneously so you don't notice it.
   / Computer Start Up Question.... #3
somethings dont show up in the startup menu
start>run then type msconfig and you can check and uncheck the things that you want or not (under the startup tab)
WARNING, take care what you turn off, something may be vital to the running of your computer
   / Computer Start Up Question.... #5
Junk go to start, programs, then look in the startup folder. If you don't like what you see right click and delete.
Better yet your wife said it's much simpler just to leave your computer turned off.
   / Computer Start Up Question.... #6
</font><font color="blue" class="small">( look in the startup folder. If you don't like what you see right click and delete )</font>
I've done that on my computer; looked, that is. And I don't like what I see; way too much stuff there. The problem is that I don't know what most of it is, so I'm afraid to start deleting things. /forums/images/graemlins/frown.gif
   / Computer Start Up Question.... #7
Copy down the name of the thing that is in the start menu and do a google search on it. Chances are, you will get lots of hits as to what it is. /forums/images/graemlins/wink.gif
   / Computer Start Up Question.... #8
<font color="blue">
</font>
Bird by deleting the icon in the start up folder you are not actually deleting the program itself, only the shortcut to it from within that start up folder. And it's easy to put it back if need be. /forums/images/graemlins/grin.gif
   / Computer Start Up Question.... #9
<font color="blue"> The problem is that I don't know what most of it is, so I'm afraid to start deleting things. </font>
Bird, If you want to post a list of what is in your startup folder, I'm sure we can give you a pretty good idea of what should stay and what should go.
Lawrence
   / Computer Start Up Question.... #10
Bird
It is an extremely rare occasion that we find anything in the Startup program menu that needs to be there. The system startup is usually were you will find important stuff like Virus protection (Msconfig/Startup). If you trace the properties back to the Directory you will more than likely understand what is loading. The less programs you run the better it will perform.! Remember all software is broken to some degree and it must interact with all the other broken software on your system
UNUSED CFG INDUSTRIAL KKT(A)27 STAND ON SKID STEER (A51247)
UNUSED CFG...
2020 INTERNATIONAL LT625 (A52472)
2020 INTERNATIONAL...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A53472)
80in HD Tooth...
AUCTION STARTS HERE @ 9AM (A51246)
AUCTION STARTS...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
